ABS system and Speedometer
Old Apr 14, 2013 | 11:49 AM
Originally Posted by zach01
i hear everyone say this but when i replaced my rear speed sensor my ABS and BRAKE lights are still on and the brakes will still lock up
You have RWAL, or 4WAL?
There are a few other switches that play a role as well. Brake switch. Ebrake switch, proportioning valve too..... any one of them can trip the lights. As can a fluid leak in the brake system.
Old Apr 15, 2013 | 09:00 AM
rjtx667's Avatar
rjtx667
Have you checked to see what codes, if any, are on?
Old Apr 15, 2013 | 10:13 AM
zach01's Avatar
zach01
you commented on my post a few weeks ago but... i have 4 wheel abs.. with 2 month old front hub assemblys(replaced them thinking that was the problem since the abs sensor are built in) when i did my fuel pump a month ago.. i looked around and didnt see any wet news around the brake lines on the frame well around where the fuel tank sits... and the rear abs sensor is only a week old...
so if i take my truck to a shop and have them hook there million dollar comuter to my truck will they be able to tell me whats wrong or am i just stuck with replaceing parts till i run out of things to change?
i did the key trick and i only get a emission evap leak code but i've had that for 5 years since i bought the truck..
Old Apr 15, 2013 | 10:56 AM
Most parts store scanners won't read ABS codes... at least, around here.... Need to go to a shop that has the right equipment, and see what is really going on. Should tell you what is really up.
Old Apr 15, 2013 | 11:39 AM
jham0077's Avatar
jham0077
On my 98 2500(2WD), the rear wheel sensor turns the speedo/runs the cruise. I just fixed the harness going to it. It was rubbed through on the torsion bar. The transmission sensor went out about two years ago and wouldn't let the tranny shift. The ABS and BRAKE lights have been on for months. The ABS light went out for a few days after I fixed the harness problem but came back on Saturday morning after replacing the right front caliper. I replaced the caliper because of a pull to the right when braking. Which it didn't fix.... I'm at the end of my rope.
And O'Reilly's scanner does nothing for brake codes. Key trick is useless also. Way to go Dodge on the 98 models.....
Old Apr 15, 2013 | 11:52 AM
merc225hp's Avatar
merc225hp
ABS codes need a proper scanner to retrieve them from the truck pcm. As you have changed out most parts brake related, chances are it's in the ABS system itself, get the codes read, then be ready to drop over $1000 in ABS parts.
See above.
Replace the left caliper, it pulls to the right so the left side braking is not working right. I never just replace one caliper I always change them both just for this reason.
Need some cheese with that wine?
Old Apr 15, 2013 | 12:02 PM
jham0077's Avatar
jham0077
Enough cheese already here. Replaced the left about a month or so ago. I have replaced singles and not had issues. Think it's a Dodge thing, and I don't understand.
Old Apr 15, 2013 | 12:16 PM
zach01's Avatar
zach01
yea thats what i ment by the millon dollar computer.. i know the regaular obd2 scanners only read and clear CELs my buddy who owns a shop has one of the computers than read everything thats going on so i guess i'll have to pay him a visit and see if he can help me out this weekend.. cuz i'm trying to get my truck all in order and in good runnning shape cuz i got a kid on the way and just want everything to work right and be safe if i let the wife drive it
Old Apr 15, 2013 | 12:18 PM
merc225hp's Avatar
merc225hp
Tear down the left side see what's going on. Have you changed the front brake lines (the flex ones?) They will swell with age on the inside, this will make a caliper not release all the way/sticky/dragging.
Old Apr 15, 2013 | 12:29 PM
jham0077's Avatar
jham0077
Will they feel squishy or soft to the push? Could that be the "darkness" floating in the reservoir? Hose linings? The pedal feels "off" to me, but I drive a Chevy(Dodge is the wife's). I gotta figure this ABS/BRAKE light thing out before I turn it over to a real mechanic.
