Fender trim
Old Apr 12, 2013 | 04:58 PM
DodgeDodgeDodge's Avatar
DodgeDodgeDodge
Default Fender trim
Hey guys, I painted my rocker panels with bed liner and it looks great. However I want to paint the fender trim with it too but how do this? I have been wanting to do this for awhile but dont know how to do it correctly.
Taping it wouldnt go well with the rounded edges. I seen some trucks on here that did just wondering how you guys did it
thanks
Old Apr 12, 2013 | 06:17 PM
merc225hp's Avatar
merc225hp
I just did the same thing last week, start with a narrow roll of masking tape like 1/2" once you have the radius down right add wider tape to the 1/2" tape. Just take your time and you will get the hang of it.
Old Apr 13, 2013 | 04:40 AM
DodgeDodgeDodge
You were able to get the rounded fenders to look good with tape?
Old Apr 13, 2013 | 09:54 AM
Use the narrow tape as suggested to start out with. It is more friendly about rounded shapes.... then use a wider tape to mask off a larger area. Takes a few tries, but, works pretty good.
Old Apr 13, 2013 | 11:41 AM
zman17's Avatar
zman17
Retired Moderator - RIP
3m actually makes tape for this purpose. Any auto store that mixes paint should have it.
Old Apr 13, 2013 | 11:47 AM
merc225hp's Avatar
merc225hp
Not on the first try but yes I was able to match the curves just fine. Tip; right after you spray the fender remove the tape asap this will let the paint edge lay flat, if you let it dry then take the tape off you will have a much more pronounced paint line/ridge.
Old Apr 13, 2013 | 12:22 PM
DodgeDodgeDodge
okay thanks alot guys, I will give this a try depending on the weather this weekend. Much appreciated!
Old Apr 14, 2013 | 02:49 PM
gdstock's Avatar
gdstock
The tale is green, and comes as thin as 1/8", all the way to 1 1/2 or 2." As mentioned, start of with the thin tape as you can lay a curve without wrinkles, then gradually lay a little wider tape with slight overlap. (Works great for stripes as well.... )
