Overdrive bucking/shake. Missfire?
Old Apr 12, 2013 | 05:20 PM
olred1998's Avatar
olred1998
Default Overdrive bucking/shake. Missfire?
Ok to start off here is the truck:
1998 dodge ram 1500 sport
4x4 reg cab short bed
83,000 miles(got it with 72,xxx)
5.9l gas 46re trans
3.55 gears and 315/75-16
3"body lift
The problem:
Truck runs great. As soon the tc locks in the truck starts bucking or shaking. other then that nothing is wrong. All gears **** perfect and it doesn't do it any other time. its bad and about 45 and then its not too bad until 55. let off it goes away. punch it and it goes away. turn od off and rides like a dream.
The good:
new plugs(stock champions), cap,rotor, newer msd 8.5mm wires.
plenum is fixed right.
new thermastat and antifreeze
new front wheel bearings and axle ujoints
tires balanced
balljoints ok still.
The bad:
steering compontents
stock shocks
that's about it
The ugly:
the whole outside the truck haha
No but I ran it by a trans shop and they tested it and said the trans is perfect. I have also replace the trans filter and fluid
I have been hunting this thing too long now.
Old Apr 12, 2013 | 05:35 PM
Engine miss. Either failing crank, or cam sensor. Getting any codes? Done a compression check? Still using oil?
Old Apr 12, 2013 | 06:16 PM
zman17's Avatar
zman17
Retired Moderator - RIP
What if anything, did you do about the cat and the o2's after the plenum fix?
Old Apr 12, 2013 | 06:54 PM
olred1998's Avatar
olred1998
No codes and not using oil. how would I go about checking the sensors.
and I haven't done anything with o2 sensors or cat. I did plenum at abot 72,xxx. I plan on putting new cat and o2s along with full exhaust soon as I get this fixed.
Old Apr 12, 2013 | 06:59 PM
Cat and O2's might be contributors to the problem. Try disconnecting the front O2 sensor, and removing it from the exhaust pipe. (it will be loud....) See if anything changes.
Old Apr 12, 2013 | 07:12 PM
olred1998's Avatar
olred1998
I didn't think the cat would cause a miss? I will try it here in a min. Seems as though y'all are sure it is a miss? could it be a fuel issue?
Old Apr 12, 2013 | 07:19 PM
aofarrell2's Avatar
aofarrell2
Miss could be caused by fuel issue. Check the cat like the experts say though - if you fixed the plenum you should have fixed the cat. Blown plenum is recipe for cat problems.
Old Apr 12, 2013 | 07:59 PM
olred1998's Avatar
olred1998
I under stand it needs to be done. removing the o2 sensor did nothing. if anything it ran worse.
Old Apr 12, 2013 | 08:33 PM
olred1998's Avatar
olred1998
also just regapped plugs and checked them. all is good.checked cap terminals and theey are all tight. still no cel even after running 5 miles with o2 taken out.
forgot to mention I am running just a cat no muffler
seems to me like the bucking has gotten worse from the time it started. after it started I replaced plugs. and cleaned capand rotor
Old Apr 12, 2013 | 08:54 PM
stewie01's Avatar
stewie01
Did you remove the sensor from the pipe or just unplug it?
