New axle assemblies required.
Old Apr 27, 2013 | 04:49 PM
  #21
If you can find an 01 parts donor.....
Grab the t-case, and rear shaft as well, if the truck is the same body style/cab/bed length as yours.
Old Apr 28, 2013 | 03:03 AM
  #22
Wombat Ranger's Avatar
Wombat Ranger
If you are worried about the cam bolt size difference, take the control arms with the axle.
Old Apr 28, 2013 | 11:24 AM
  #23
00sidekick00's Avatar
00sidekick00
Was planning on getting a lift kit after the axle switch probably get one with control arms but I'll grab then as a backup thanks. also interesting thing I learned, when all else fails you can call Chrysler to get a vin decoded.
Old May 1, 2013 | 11:32 PM
  #24
00sidekick00
Found my donor truck, ended up going with your rout merc225hp bought the whole truck (-blown motor) may be able to save 3 others that way. this however provided some interesting options for me, the donor is a 2500 with a 5.9 360 and as far as i can tell a nv241 i've read that it can be switched with the nv231 that i currently have as long as the input drive is switched are there any posts about doing this or can someone explain what i would need to do to get it to bolt up to my current trans.
Old May 1, 2013 | 11:43 PM
  #25
Wombat Ranger
You shouldn't even need to swap the input. They are both 23 spline inputs. Should just be a bolt in deal.
Read this. You should consider it with your Tcase upgrade.
https://dodgeforum.com/forum/2nd-gen...241-np243.html
Old May 2, 2013 | 12:18 AM
  #26
00sidekick00
Thank you wombat i shall try and get that done. so if the t-case is a bolt up to my 01 would the transmission be a bolt up to a 97 360?
Old May 2, 2013 | 12:22 AM
  #27
Wombat Ranger
Other than the sensors/electronics being different yes. They are both 360 automatics right?
Old May 2, 2013 | 12:26 AM
  #28
00sidekick00
yes sir they are both 5.9 360 automatics, one is a 97 one is a 98. how are they different? seeing as to how these questions have veered off of my original topic is it better to start a new thread?
Old May 2, 2013 | 01:37 AM
  #29
Wombat Ranger
I am the wrong person to ask about the auto's. I'm a manual transmission guy.
Old May 2, 2013 | 07:45 AM
  #30
00sidekick00
Well when I find a nv4500 I'll come calling for you in the meantime do you know any members that I might talk to for automatic questions?
