wiring harnesses??
Try resetting the pcm first and see what works and doesn't work. Also try this after and see if you get any codes. http://dodgeram.info/Engine-Gas/OBDI/pcm_fault_code.htm
the lines have been cut and have bubba reworks in them (rubber line with hose clamps) so there was probably one there. I still have the 4 codes (down from 11) 37, 45 have to deal with the tranny, the other 2 are both dealing with the o2 sensor which is the other wiring harness I was talking about. They straight piped that so it doesn't exist right now
I did the rear band adjustment, changed filter and fluid when I did so. Drove great for 2-3 days (I only put 11 miles on it a day) On my way in to work. It started from stop fine then up shifted, then it started acting like it was in neutral. I stopped turned it off and re started ran for a lil bit did it again. I parked it after work started it and nothing no reverse no drive!?!?!?!?!?
