Thoughts On Doing This For Fuel Pump....
Old Apr 29, 2013 | 05:11 PM
  #21
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by h3lzsn1p3r
this is true I never considered where you live here in the rust belt the box bolts are a pain to remove its easer to undo the 2 bolts on the tank from experience up here
Removing the bed is crazy (IMO) no matter where you live. And those 2 bolts (and the clamp for the fill tube) will even be way easier for the OP, if he has no rust like we do.
Old Apr 29, 2013 | 05:28 PM
  #22
h3lzsn1p3r's Avatar
h3lzsn1p3r
exactly my thoughts I would never have thought to pull the bed seems like 2x more work plus buying beer for friends needed brings the price up even more
Old Apr 29, 2013 | 10:21 PM
  #23
Jr. Mechanic's Avatar
Jr. Mechanic
Why do you think removing the bed is crazy? Have you ever removed a bed?
I've changed a lot of fuel pumps, and have pulled even more beds. I'm an auto body tech and typically pull at least one bed a week.
With nothing more special than a standard 1/2" drive impact, I can have the bed off any GM or Dodge truck in a matter of 15-25 minutes as long as I'm not dealing with a cap or cargo cover on the bed. This also includes removing the rear bumper to avoid damaging the bed corners. Fords I can have off even faster if there isn't a bed liner (6-8 T50's from the top), although those T50's often get seized in their U nuts which can be a pain..
It's not hard, it's not crazy. I've done it both ways, and it really depends on the vehicle. Sometimes it's easier to drop the tank, sometimes it's easier to pull the bed.
Personally, if pulling the bed is an option, I'd much rather remove 6 18mm's, and a few 7mm's from around the filler neck than deal with rusted straps and risk disturbing the aging rubber filler and vent lines. Not to mention, leaving the tank secured and level makes less of a mess and is quite a bit easier to swap the pump assembly.
Old Apr 30, 2013 | 10:06 AM
  #24
h3lzsn1p3r's Avatar
h3lzsn1p3r
yes but you have the tools the op does not he was going to use an office chair as a tool besides I do 3-6 fuel pumps a week every time the tank goes down and if the straps are rusty the get replaced why would you leave rusted straps on there that's asking for trouble
now to the op you have heard of the different ways its up to you to choose instead of us arguing because we do it different
Old Apr 30, 2013 | 11:20 AM
  #25
J415's Avatar
J415
I use to be anti-removing the bed inorder to get to the fuel pump. Then my fuel pump went out...AFTER I filled my tank up with gas. Took me about 3 hours to get it all done and it was very easy. If I had to do it again, I'd remove the bed and take it from there.
Old Apr 30, 2013 | 03:06 PM
  #26
DodgeRam10's Avatar
DodgeRam10
How much does the bed weigh approximately if I were to go that route?
Old Apr 30, 2013 | 07:04 PM
  #27
zman17's Avatar
zman17
Yea that.
You have the means to do it that way, I doubt the OP does. Not to mention all the wiring/plugs that need to be disconnected at the back if there is a tow package especially and maybe damaged.
+1 on that.
3 hours? Problem is , we all have different tools and different means to do certain jobs.
Too much for less than 3 or 4 people.
Old Apr 30, 2013 | 10:00 PM
  #28
DodgeRam10's Avatar
DodgeRam10
Ok so I just dropped it, I also found the canister that the vacuum line is supposed to connect to was broke off. This might explain my evap light ive been getting the last few months. What is this thing called? The canister thing on the fuel pump that needs to be transfered over to the new pump? I might be able to slip a vacuum line on it still but the fitting coming out of the canister broke off.
Old Apr 30, 2013 | 10:27 PM
  #29
DodgeRam10's Avatar
DodgeRam10
nevermind, I think that is the pressure relief rollover valve so I guess its not that critical that the end is broke off huh?
Old Apr 30, 2013 | 10:54 PM
  #30
h3lzsn1p3r's Avatar
h3lzsn1p3r
we need pics man otherwise your just typing aimlessly
