Thoughts On Doing This For Fuel Pump....
Old Apr 24, 2013 | 07:29 PM
DodgeRam10's Avatar
DodgeRam10
Default Thoughts On Doing This For Fuel Pump....
So my fuel pump took a dump today with over a half a tank of gas. I know I can drop the tank after siphoning or have heard of people pulling the bed off. I thought about doing this and found after research that a lot of eople actually do. What are your thoughts? I can cut it out the bed and make a riveted hatch and seal it that way if the pump ever goes out again or if the $84 ebay pump I just bought is defective,I can change it out in a half an hour or so...seems good to me.Here's a link
Old Apr 24, 2013 | 07:37 PM
zman17's Avatar
zman17
Retired Moderator - RIP
IMO, taking the bed off is ridiculous. I've also always thought about making a removable lid too. But , I'd still drain and remove the tank and get it away, before doing the mod. And if you are getting an $84 fuel pump, I suggest you prep for replacing it again anyway before too long.
Old Apr 24, 2013 | 07:46 PM
DodgeRam10's Avatar
DodgeRam10
Yea I'm worried about the cheapness also but local store wanted $220 and $84 sounded like it was worth a shot,one year warranty also. Agreed that removing before cutting would be best but do you think if i used a reciprocating saw it would be alright? I dont think there would be any sparks and I could do one side,let it cool,then continue on...
Old Apr 24, 2013 | 07:58 PM
jnellydodge's Avatar
jnellydodge
I too never got the point of pulling the bed off F THAT.
I just used my atv/motorcycle jack and dropped the tank using that on my 93' & the 98' I used to have. ITS EASY.
EDIT: I think on the 2nd gens if you cut an access hatch you will be sacrificing the strength of the bed because there is a support member directly above the fuel pump, and to cut that access hatch you would have to cut thru that support member. BAD IDEA don't do that.
EDIT #2: Watched the video, support member will be cut. I would NOT do that.
Old Apr 24, 2013 | 07:59 PM
zman17's Avatar
zman17
Sorry, but I'd remove the tank before doing that. End of story. LOL Anything else and you are risking your life.
Old Apr 24, 2013 | 08:16 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
My main gripe with it is the brace being cut.
Old Apr 24, 2013 | 09:23 PM
DodgeRam10's Avatar
DodgeRam10
I guess i'll have to suck it up and drop the tank.....damn brace
Old Apr 24, 2013 | 09:33 PM
QuadCabLuv's Avatar
QuadCabLuv
At work I prefer lifting the bed off, but that is because I'm using a lift. Takes me all of 10 min to get the bed up high enough to access the tank.
Old Apr 24, 2013 | 09:43 PM
DodgeRam10's Avatar
DodgeRam10
Well unless I pop a can of spinach and turn into the hulk....theres no way I can lift it by myself. Would be nice to have a lift though..
Old Apr 24, 2013 | 11:11 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
just drop the tank rig up a stable platform for 1 jack or have a friend help with 2 jacks and drop the tank with 1/2 a tank full easy
