new 2wd front bearing/hub play
Old Apr 26, 2013 | 10:35 AM
Mic the spindles. Not sure what spec is on them though.... I would think that properly torqued, they shouldn't have ANY play.
Old Sep 6, 2015 | 05:36 PM
Unclluke's Avatar
Unclluke
Default Same problem!
Mine is a 2000 and I am having the same issue. What did you find out?
Old Sep 7, 2015 | 08:37 AM
ryanmc's Avatar
ryanmc
bought new genuine oem bearing from a dodge dealer on fleabay 60 bucks no play
Old Sep 7, 2015 | 09:05 AM
Unclluke's Avatar
Unclluke
Default That's crazy
I can't believe they would sell bearings that were not the right size? When you slid the new one on was it tight enough you had to tap it on?
Old Sep 8, 2015 | 12:26 PM
Unclluke's Avatar
Unclluke
anyway you can list the part number? Or the seller or something? I just bought another one today. It is a MOOG and it says OEM alternative but I don't know what is going to happen.
Old Sep 9, 2015 | 07:02 AM
ryanmc's Avatar
ryanmc
it slid right on no tapping,part number 52009867AB the sellers name was sherman dodge. did you have a loose replacement?
Old Sep 9, 2015 | 08:30 AM
Unclluke's Avatar
Unclluke
Default Replacement
The new one was loose. It also had the abs ring on it which my vehicle doesn't have. The moog part shows tomorrow. I can't believe they would sell stuff that doesn't fit. Are there spindles that this loose part does fit on? I just wonder why these people are still making these parts 16 years later.
Old Sep 10, 2015 | 04:41 PM
Unclluke's Avatar
Unclluke
Ok guys, for anyone else who reads this years later with the same problem. The first hub I ordered was cheap. It was part number 295-15084. I installed it correctly by sliding it on the spindle and torqueing it while in the air. After putting the tire on I had more play in the tire than before. I than ordered the MOOG version which says it is OEM equivalent. After installing this part it was PERFECT! Just make sure the part you order says OEM or OEM alternate. The previous part did not. The hub nut can be used up to three times and I secured it with locktite but that is up to you. Good Luck and thanks ryan.
