2001 Ram 1500 5.9 4x4 Sport A/C Not working
Old Apr 29, 2013 | 11:26 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Then likely your compressor is toast. Or the clutch is bad.
Old Apr 30, 2013 | 03:10 AM
ChrisFischer's Avatar
ChrisFischer
so is it the compressor and clutch than? since nothing happened by jumping the low side switch
Old Apr 30, 2013 | 05:40 AM
ChrisFischer
ok thank you not what i wanted to hear but rock auto parts out of madison wi has one for 140.00 brand new
Old Apr 30, 2013 | 11:14 AM
Bypass the high-side switch as well before shelling out the cash for a new compressor.
Verify that the circuit is actually being grounded as well.
Old May 1, 2013 | 06:31 AM
ChrisFischer
I bypassed the high also and nothing at all
Old May 1, 2013 | 10:08 AM
Ok, apparently, on the 01, the clutch is powered via a relay, that is controlled by the PCM. Are you actually getting power to the compressor?
Old May 2, 2013 | 07:16 PM
Motor_Head_Jr.'s Avatar
Motor_Head_Jr.
Hi all I am Having a similar problem but on mine, the compressor will engage when the low pressure side is bypassed, so my question is where would i find this relay or check it to see if it's bad?
Old May 2, 2013 | 07:40 PM
If the compressor runs when you jump the low pressure switch, the relay is fine. You are simply low on refrigerant. (which implies you have a leak somewhere.)
Old May 2, 2013 | 08:31 PM
Motor_Head_Jr.
That's What i thought but the compressor runs very quiet when engaged, shouldn't there be some noise if the refrigerant level is low?
Old May 3, 2013 | 06:56 AM
ChrisFischer
my relays are good i have to go buy a test light to see if there is power later today
