3500 coils and leafs swap into 98 ram 1500
Old May 3, 2013 | 11:37 AM
buyndsell69's Avatar
buyndsell69
Default 3500 coils and leafs swap into 98 ram 1500
so i brought 3500 coil springs and leafs from a 97 v10 dodge, wondering how much lift i will get out of the springs and leafs? i already swapped the rear blocks and that gave me 1.5-2" lift already in the rear.
Old May 3, 2013 | 11:40 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
About 2 in for the coils.
The leaves won't work unless you've got some fab skills as the perches in the D60/70/80 rear axle on the heavy trucks are wider than that of your 9.25 1500 rear end. The shakles and frame mounts are also different IIRC.
Also, 2500 rear springs are bad enough, 3500 springs are going to be even worse. You might actually be better off with getting an add-a-leaf for the rear. You'll get about 2 in of lift out of those and an increase in payload without squat.
Welcome to DF btw.
Old May 3, 2013 | 11:46 AM
buyndsell69
Thanks, if i went to a junkyard and picked up the bracket that the u-bolts slid into under the axle from the 3500 would it work with the 1500 axle? i already got new u-bolts made for the 3500 leafs, im taking out the 1500 leaf "pack", and just putting the 3500 "pack" in and just bolting em in.
Old May 3, 2013 | 03:00 PM
dodge dude94
I suppose if you want to do a bunch of cutting, you could do that. You would need to cut the perches off the 3500 axle, and the shackles/mounts off the frame.
Old May 4, 2013 | 07:52 PM
jasonw's Avatar
jasonw
Site Moderator
For future reference:
https://dodgeforum.com/forum/dodge-r...s-section.html
Old May 4, 2013 | 08:49 PM
redneck_ram's Avatar
redneck_ram
if you want to unload those 3500 leaf packs, ill gladly take em off your hands...
Old May 4, 2013 | 09:31 PM
rtaylor's Avatar
rtaylor
i have a set of 2500 leaf packs from a 97 2500 diesel that i will sell but shipping......WOW
Old May 4, 2013 | 09:41 PM
redneck_ram
where are you located?
