valve cover gasket replacement shocker
Old Jun 2, 2013 | 02:04 PM
  #51
h3lzsn1p3r's Avatar
h3lzsn1p3r
Originally Posted by xplorer82
haha we'll see. itll have to be a in cab vid
like a dumbass, I welded it up and didn't check to make sure o2 sensor had room to clear trans pan. damnit, here we go again. glad I got beer in the fridge!!
some times the simplest things can be the worst
Old Jun 2, 2013 | 06:57 PM
  #52
gdstock's Avatar
gdstock
Minus the front fender, that actually doesn't look bad.
Any hint of the previous history? Female owned? Anything?
Looks like somebody missed several oil changes...
Really? Going there? I guess a guy would not have neglected a truck.....
OP - keep in mind that anything you use to break that stuff up will likely clog oil pick up at some point. So when you do, prepare to drop pan at some point (not too bad a job) and clean pan and pick up.
Old Jun 2, 2013 | 07:36 PM
  #53
stewie01's Avatar
stewie01
I think he's already dropped and pan and cleaned things up down there....
Old Jun 2, 2013 | 07:49 PM
  #54
gdstock's Avatar
gdstock
But after more breaks loose, it may need it again. Better than clogging line and shelling out engine! May take some time for that much crud to all come loose. Don't think I have ever seen one that bad.
Old Jun 2, 2013 | 10:35 PM
  #55
xplorer82's Avatar
xplorer82
no doubt bud. no biggie dropping the pan again. im sure glad I don't mind getting my hands dirty.
correct.
oh im sure its going to need it again. ive got about 450miles on it since I did all that. gonna do seafoam then oil change at about 500miles. then probably drop pan on the oil change after that if everything is still going good.
Old Jun 2, 2013 | 11:19 PM
  #56
merc225hp's Avatar
merc225hp
The next time you have the pan off you might consider changing the rear crank seal as well if not done already.
Old Jun 3, 2013 | 03:15 AM
  #57
Gaius's Avatar
Gaius
There's no way i would have spent that much time on cleaning without a rebuild, or at least a used motor. I would have opened the valve covers, saw it, and immediately put the new gaskets on without doing anything until I was ready to pull the engine.
Old Jun 3, 2013 | 06:07 AM
  #58
BradLittlefield's Avatar
BradLittlefield
Which would have been about 50 miles later when it became an expensive lawn ornament
Amazing how terrible this engine looked and it still runs... That plug!!! I've never in my life seen anything like that. Hopefully all that work was worth it!
Old Jun 17, 2013 | 09:55 PM
  #59
xplorer82's Avatar
xplorer82
yeah brad I can tell it was worth it. engine runs much better and smoother. anything is better then what was all crammed in there. my valve covers and engine bay get hotter then I would like but I might be due for a fan clutch and water pump anyway.
well I dumped 1/2 a bottle of seafoam in it and ran the **** out of her and amazingly, no smoke show, like none at all, wtf? I said screw it, changed the oil and filter. maybe i'll try a full can next time, I dumped the other 1/2 in my tank to clean the injectors.
since then, ive obviously got the gutted cat back up, sealed leaks (I suck welding on my back in gravel lol), few days later I couldn't take it anymore so I threw on my Edelbrock SDT muffler. luv the dodge power/sound. that muffler goes well with the 360. now I gotta buy one for Blue (98).. I think im going to go with the dynomax VT for her.
now I have to find out why I still have hesitation/a little stumbling/no power really till 3k rpms. soon as she hits 3k she takes off like a bat outta hell. ive done some searching but all I see is "cats clogged", "Plenum", "pre-cat o2", "plugs/wires/cap", "TPS" and possibly the "MAP sensor"..
well, cats gutted, just installed new gaskets all around, swapped front o2 sensors (used but still good("I think") from the 98), new champion copper plugs, newer accel wires, newer cap (not sure if rotor was done, guessing so), New TPS (ecklin(?) from napa, same as in my 98), I know the MAP nipple was cracked, poor mans fix was a little electrical tape. think i'll run a new line for that this week maybe. kinda running out of ideas on the no power till 3k. any ideas, toss 'em out please.
Old Jun 17, 2013 | 10:27 PM
  #60
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
I'd be looking at a vacuum leak at the MAP, a bad MAP, or bad O2 sensors. Does it do it when cold, hot or all the time?
