5.2 to Hemi swap
Old May 14, 2013 | 12:54 AM
Mixamatchi's Avatar
Mixamatchi
Default 5.2 to Hemi swap
So, I want a Hemi in my 98 ram 1500. I intend to use a megasquirt for fuel and ignition. My question is this: can I leave the stock pcm in place for things like running the dash/tach/etc..? My thought was to adapt as many sensors as necessary, but leave the fuel and spark from the stock pcm disconnected. I was hoping, that I could adapt the original style crank sensor to allow tach operation.
Thoughts?
Trans will remain NV3500 5speed.
Old May 14, 2013 | 05:44 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Good luck with that. Do a search here on DF. There is a long running thread on this topic. Been years and it still isnt running. Not worth it IMO. But find that thread, it has has a lot of info in it.
Old May 14, 2013 | 06:13 PM
Ham Bone's Avatar
Ham Bone
Does that transmission even match a hemi?
Old May 14, 2013 | 06:40 PM
Mixamatchi's Avatar
Mixamatchi
I searched hemi swap, but haven't found what I'm looking for. I keep finding swaps involving integrating the stock pcm into the earlier wiring harness. I can see that as a significant obstacle. I intend to use a "stand alone" system for this reason. I just need to know how much feedback the 98 pcm in my truck needs, and how it receives a tach signal. Met a guy once with a high 9 second dakota. His dash still worked using the stock pcm, although none of it was connected to the motor.
Old May 14, 2013 | 06:43 PM
Mixamatchi's Avatar
Mixamatchi
To my knowledge, the hemi has the same bell housing pattern as any LA small block. I have seen mention that the top bolt hole is absent, but the rest line up. I'm sure there will be some measuring going on.
Old May 14, 2013 | 07:35 PM
stewie01's Avatar
stewie01
This guy put a Hemi in his Dakota, should be fairly similar to putting one in a Ram, https://dodgeforum.com/forum/2nd-gen...with-pics.html
Old May 14, 2013 | 08:33 PM
Mixamatchi's Avatar
Mixamatchi
Thank you for the link. It was very informative, but not what I'm looking for. I can handle the welding, and fabbing. I can handle the wiring too, as far as making the motor run. I really need to know how the stock pcm from my '98 ram works, more than I need hemi info. Maybe I should have titled the thread differently. Again, I intend to operate the fuel and ignition with an aftermarket computer. What I want to keep stock is just the dash, namely the tach. I think I can rig up the stock crank sensor set up, and I want to know if the tach will function based on this output. I know it will have a permanent check engine light- don't care. I know I will lose cruise control- no biggie. I will have complete control over the fuel and ignition curves, and I won't need a little magic box with a downloaded tune to get it, just a laptop.
Thank you for the replies, everyone. Can anyone answer the above question ? Should I make a new post somewhere else, and maybe ask the question better ?
Old May 14, 2013 | 09:02 PM
stewie01's Avatar
stewie01
You might need to find someone who does custom PCM's and see what they have to say...
Old May 14, 2013 | 09:11 PM
Most of the dash gauges are driven via the PCM, thru the central timer module. I think it would be easier to just install different gauges....
Have a read of this thread.
Old May 15, 2013 | 02:32 PM
zman17's Avatar
zman17
That's the thread I was referring to, thanks HeyYou.
