Need V10 HELP!!!
Old May 26, 2013 | 08:34 PM
2001dodgeramv10's Avatar
2001dodgeramv10
Default Need V10 HELP!!!
Bought a 2001 2500 V10 with 55,000 miles, the PO used it solely as a plow truck for the past 2 years. Now I have problems with it loosing power on acceleration and it backfires some. Doesn't do it all the time, runs fine then when I stop and take off no power and "bucks" some and other times just fine. Haven't drove it at all because I don't dare to take it anywhere. Replaced the coils, spark plugs, TPS. What else could it be, already had 1 new head installed because it went out when I was trying to figure out this problem, running out of money trying to fix this GEM. Any help would be great... Thanks
Old May 26, 2013 | 08:37 PM
Read the plenum sticky.
Old May 26, 2013 | 08:53 PM
stewie01's Avatar
stewie01
Don't think the Plenum thread will help his V10 too much....
Old May 26, 2013 | 09:06 PM
Jimythefan's Avatar
Jimythefan
Is it throwing any codes? If it was used as a plow truck, the fuel may have varnished the system from sitting. Have you run any fuel system cleaner through it? How did the plugs look? Did you do plug wires with the plugs? Sometimes they dry out and will cause miss firing.
Old May 26, 2013 | 09:45 PM
Oh snap! My bad....one too many PBR's...if there is such a thing....
Old May 26, 2013 | 09:47 PM
stewie01's Avatar
stewie01
Ya know people were drinking that stuff like crazy at Carolina Rebellion. I didn't try one. Maybe I should have....
Sorry to thread jack OP.
Old May 26, 2013 | 10:10 PM
2001dodgeramv10
Thanks for the responce, I have run thru a tank of fuel with 2 bottles of sea foam, New spark plugs and wires. It just came back from the repair shop after having the head and head gaskets done ( start of my nightmare). Thank you
Old May 26, 2013 | 10:28 PM
stewie01's Avatar
stewie01
Take that thing back to the shop!
Old May 26, 2013 | 11:58 PM
Paul DeHayes's Avatar
Paul DeHayes
Haha PBR? You're a soldier ain't ya? LOL.......btw I'm not too far away from you in Greenville SC
Old May 27, 2013 | 08:48 AM
Jimythefan's Avatar
Jimythefan
If it runs fine part of the time, then it was put back together properly. If there's no codes, theoretically then the sensors should be good. It sounds to me like fuel issue still.
