2001 dodge ram 1500 spacer exchange
Old May 31, 2013 | 07:12 PM
Lawson961's Avatar
Lawson961
Default 2001 dodge ram 1500 spacer exchange
Hello, I just put a new spacer on my 2001 dodge ram 1500 4x4 5.9L. I cannot get the truck to go into park, the brake lights do work, I have tried the Neutral Safety Switch, & all the modules.bur, I don't know what the issue is now.
Old May 31, 2013 | 07:14 PM
Gaius's Avatar
Gaius
What spacer? You mean a body lift?
Old May 31, 2013 | 07:35 PM
Lawson961's Avatar
Lawson961
No, the spacer that connects the transmission to the transfer case.on the very back end of the trannsmission
Old Jun 1, 2013 | 01:57 AM
Gaius's Avatar
Gaius
Likely just a cable adjustment. Try that first.
Old Jun 1, 2013 | 10:47 AM
May have misaligned the park linkage inside the trans, as I think it engages somewhere in that extension housing...... Was the truck in park while you were changing it?
Old Jun 1, 2013 | 01:14 PM
Lawson961's Avatar
Lawson961
Okay, thank you all!
Lawson961's Avatar
Lawson961
No it was neutral!
Old Jun 1, 2013 | 04:45 PM
Lawson961's Avatar
Lawson961
It was in neutral.
Old Jun 1, 2013 | 06:25 PM
Grab the 01 service manual from the faq section, check out the transmission stuff, and look at how the park linkage is supposed to work..... Should be able to figger it out from there... but, it probably does mean dropping the t-case and extension housing again...
Sorry man.
Old Jun 1, 2013 | 06:42 PM
Lawson961's Avatar
Lawson961
Okay, thank you!
