Does anyone have a pdf for the valve body, I want to double check one thing on the tv arm. There is a sleeve on the end of the tv itself and I can't find which direction it goes .
So I'm pretty sure I figured it out. Apparently I did air check the right hole so the front clutch does have a leak. So pulled my tranny back out and pulled it apart. So now is to figure out whete its leaking.
I figured that when the tranny is sitting up on the bell housing the clutches don't leak but when its laying side ways under the truck it is. I guess i was'nt using enough air pressure to check this.
To conclude this thread I found my front clutch housing that I bought used because mibe was destroyed from metal to metal missing a inside seal so after fixing that and the intermediate accumulator(and the reverse band and reverse drum from slipping) the tranny is running great! Thank you everyone for your help.
