Last edit by: IB Advertising
Browse all: Interior
- Dodge Ram 2nd How to Repair A/C Water Leak Under Passenger's Side Dash
Step by step instructions for the do-it-yourself repairs.
98 Ram 1500 AC water leak in cab passenger side.
Could also be the heat core leaking. Not sure why mine leaked when I ran my A/C, but it stopped when I bypassed it. (I also live in South Texas, so I don't need heat.) It's worth looking into.
But also check into the drain valve, it should be along the firewall on the passenger side. There's multiple ways to de-clog it. Last time it clogged on me, I declogged it just by sticking my pinky in there. (Dust had built up and eventually clogged it up at the end.)
Good luck.
Good luck.
If you're not smelling any coolant, than most likely not the heater core. I agree w/ the other guys on the drain tube on the pass side in eng bay. I lost the hose somehow & just the pressure difference from running down the road caused the water to come back inside. Put a hose on there if there isn't one, preferably w/ a 90 on it & you should be good to go.
Trending Topics
There is no hose originally, just the nipple. Inside needs to be unclogged. And if it's that bad, the HVAC box should be removed and cleaned, along with heater core and ac core replacement. They are both rotting because of the debris thats inside. And it wont be long until one or both start leaking anyway.
