trans to transfer case leak
Old Jun 17, 2013 | 12:49 PM
zman17's Avatar
zman17
Retired Moderator - RIP
There is a small risk if both seals are bad. Which is why you want to use atf+4 in both. Remove the fill plug from the TC and see if it's getting overfilled. If the fluid is going into the TC , not that big of deal, but you don't want the RP getting into the trans.
Old Jun 17, 2013 | 08:22 PM
dhvaughan's Avatar
dhvaughan
Originally Posted by bigaaron
is there any risk of cross contamination of the fluids?
no. none. zero. nada. no way jose. both units are sealed and there is a drain gap between the 2.
do I need to drain just the tcase? or both?
if you are removing them, there is no need to drain either. t-case only holds about 1 quart of ATF+4 by the way which is red..... auto trans holds about 12 quarts but its so damn heavy you need a jack or a friend named paul bunyon, so draining it has no effect other than making a huge mess where you are trying to work.
just because your leak is red, don't assume it the trans. both use ATF+4.
Old Jul 2, 2013 | 03:17 PM
bigaaron's Avatar
bigaaron
sorry for the delayed response i recently broke my ankle, but i am still going to have a go at it.
Old Jul 2, 2013 | 06:26 PM
dhvaughan's Avatar
dhvaughan
how did you break your ankle? playing softball?
Old Jul 3, 2013 | 01:27 AM
spelunkerd's Avatar
spelunkerd
New Member
Funny, I've got the same issue (98 Ram) and today I planned to search the topic here. Not losing much fluid, but I'm not sure which seal is bad. I might just change both while I'm there. I guess I could put in some UV dye but there's not much point.
Old Jul 3, 2013 | 08:17 AM
Seals aren't terribly expensive..... if you are going to be RIGHT there, replacing both is the best plan.
Old Oct 5, 2013 | 04:13 PM
bigaaron's Avatar
bigaaron
forgot to respond - I changed the seals and also did the tail seal - all is right with the world again.
