Advice needed on Tires
Old Jun 22, 2013 | 06:43 AM
grover2044's Avatar
grover2044
Default Advice needed on Tires
Hey guys,
Been looking at a used set of Toyo Open Country A/T's which are 31x10.5R15 on aluminum rims 5 on 5.5 bolt pattern... I know the rims will fit, just curious what you guys think about running a 15" tire versus the 16"... I have 285/75/16's on it now and am looking to get some gas mileage back, and well less strain on the driveline seems like a good reason too lol...
Think they will look to small?
Old Jun 22, 2013 | 07:20 AM
kejobe's Avatar
kejobe
The 31's are equivalent to 265/75/16's, which is a stock size tire. Your 285's are equal to a 33" tire. As long as the 15's will fit, go for it, there won't be a noticeable difference between them and 16's.
Old Jun 22, 2013 | 11:52 AM
Johnn123's Avatar
Johnn123
I dont see it being a problem at all, I dont think you should notice the difference at all either using 15's as opposed to 16's either. I say go for it, only problem might be wheel wells looking less full, but thats cosmetic.
Old Jun 22, 2013 | 12:38 PM
PrestonEidsmoe's Avatar
PrestonEidsmoe
This is what the difference in size actually is:
Specification Sidewall Radius Diameter Circumference Revs/km Difference
285/75-16 8.4in 16.4in 32.8in 103.1in 614 0.0%
31/10-5 0.1in 2.6in 5.2in 16.5in 3846 -84.0%
265/75-16 7.8in 15.8in 31.6in 99.4in 637 -3.6%
Just pretend there is a line going straight down in each row. Sorry, couldn't get it to transfer properly. This is a tire selection chart. May be it will help? http://www.miata.net/garage/tirecalc.html
Old Jun 24, 2013 | 09:06 AM
grover2044's Avatar
grover2044
Thanks guys for the comments and info much appreciated... Going to this size tire will really increase mpg? and less wear on the drivetrain?
Old Jun 24, 2013 | 09:15 AM
Yep. Smaller diameter, lighter tire. Less rolling resistance. Probably pick up a point or so on gas mileage.
Old Jun 24, 2013 | 10:49 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
if he keeps his foot out of it. LOLz :P
Old Jun 24, 2013 | 11:47 AM
grover2044's Avatar
grover2044
LOL I try my best!... really not as concerned about the gas mileage as much as lessening the strain on the drive train....
Old Jun 24, 2013 | 12:01 PM
Properly maintained, won't make that much of a difference on parts longevity.
Old Jun 24, 2013 | 02:28 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
You'll be able to flex better with that 3" lift you've got too.
