99 Ram 1500 Trans issue
Old Jun 24, 2013 | 01:18 PM
JoshHager's Avatar
JoshHager
Default 99 Ram 1500 Trans issue
I have a 1999 Ram 1500 2wd, 5.2L. Earlier this past week my check engine light came on. I had it checked and the code it is pulling is P1763. It indicates that my Governor pressure sensor input was to high. The truck is still running but it accelerates really slow from a stop. Would replacing the pressure sensor and the solenoid take care of this problem?
Old Jun 24, 2013 | 01:27 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I'd drop the pan and see what it looks like in there. And I don't think it has anything to do with "accelerates really slow from a stop" . You most likely have other issues, like the plenum maybe.
Old Jun 24, 2013 | 01:35 PM
May be starting off in second gear...... (limp mode)
Old Jun 24, 2013 | 01:39 PM
zman17's Avatar
zman17
That is possible for sure. I have a great 1763 code sheet. Problem is I cant paste it here. Remember that file I sent you a couple years ago? Same one. I see PDF files posted in the FAQ/DIY section. Veeten for instance. How did he do it? LOL
Old Jun 24, 2013 | 02:19 PM
Haven't a clue. Might ask one of the admins.
Old Jun 24, 2013 | 05:20 PM
JoshHager's Avatar
JoshHager
Zman, if I PM you my email address could you possible send me that PDF file for the 1763 code sheet?
Old Jun 25, 2013 | 12:00 AM
gdstock's Avatar
gdstock
OR...Zman, you could upload it to Dropbox and post a link....so everyone can have a copy that wants one. (You can send it to me and I will load in Dropox and post link if you don't want to set one up....)
Old Jun 25, 2013 | 11:52 AM
zman17's Avatar
zman17
I sent it in an email too josh.
But Yea, PM me. GD
Old Jul 8, 2013 | 06:01 PM
JoshHager's Avatar
JoshHager
Thank you the input and advice. I dropped the pan and pulled off the valve body. Replaced the Governor pressure sensor and solenoid. The lockup/O.D. solenoid and wire harness, the 3-4 accumulator spring and speed sensor. Put a new filter in and new pan gasket. Put everything back together and it is running nice and smooth.
Old Jul 9, 2013 | 11:39 AM
zman17's Avatar
zman17
Good deal, and thanks for getting back to us.
