OIl Filter leaking
Old Jul 8, 2013 | 11:34 AM
WAGNASTY3's Avatar
WAGNASTY3
Default OIl Filter leaking
So my truck wasn't leaking until I changed the oil. It seems like its coming out of the oil filter itself. Its tight, and went on smooth, just cant figure out why it would start. This is my second one since it started happening. The first was a wixx oil filter. Anyone might know why?
Old Jul 8, 2013 | 01:12 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Welcome to DF. Please post tech questions in the tech section. Not here in the FAQ/DIY section. Thanks I'll move it for you.
Old Jul 8, 2013 | 01:35 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Sounds like the gasket (o-ring) from the old filter stuck to the filter adapter and you now have a condition of it having been "double gasketed". If you have the old filter, verify the gasket it still on it.
Old Jul 8, 2013 | 02:15 PM
WAGNASTY3's Avatar
WAGNASTY3
Ok cool Ill check that out when I get home thanks.
Old Jul 8, 2013 | 02:47 PM
abdodge1500's Avatar
abdodge1500
+1, that happens when people don't put a light film of fresh oil on the o-ring when doing an oil change.
Old Jul 8, 2013 | 03:06 PM
WAGNASTY3's Avatar
WAGNASTY3
Yea I did that with this oil change, thinking it would stop it but it didnt.
Old Jul 8, 2013 | 03:28 PM
zman17's Avatar
zman17
Also make absolutely sure it's going on straight and the previous owner didn't cross thread .
Old Jul 8, 2013 | 05:59 PM
bigaaron's Avatar
bigaaron
+1 on the double gasketing. Pull the filter off and see if you have either 1.) the gasket from the previous filter is stuck to the mating surface or 2.) stuck to the gasket of the new filter
did you happen to overtighten and crush your new filter?
Old Jul 8, 2013 | 07:06 PM
kejobe's Avatar
kejobe
^^^Agreed on all. Filter only needs 1/4 to 1/2 turn past snug. And definitely oil the new gasket before it goes on.
