ABS, Check engine and Brake Lights on Help
Old Jul 14, 2013 | 04:09 PM
gertie240's Avatar
gertie240
+1 on going to a good brake shop. Look on yelp for feed back about local shops then call them. I like to get to know any shop I need to use. And see if you can swing an appointment during the week. Like everyone else, those people have lives outside of work. Also a dozen doughnuts can't hurt.
Old Jul 15, 2013 | 11:11 AM
DE3PT's Avatar
DE3PT
Hey man, mine dun the same thang an all i did wuz replace the sensor on top of the rear-end housin. i'm sory i cant remembr watt they call it, but its the ONLY sensor on the bak rear-end housin. i hope this helps ye.
Old Jul 16, 2013 | 09:41 AM
bmcarey1988's Avatar
bmcarey1988
Do you mean the rear end differential for the abs sensor. Ib replaced the sensor. On that.
Old Jul 18, 2013 | 02:00 AM
MikeDuff's Avatar
MikeDuff
I'm having this exact problem on my 06 1500. All three lights come on- CEL, ABS and Brake lights came on. I have scanned and all I get are codes U0120 and U1120. Any ideas?
Old Jul 18, 2013 | 02:01 AM
MikeDuff's Avatar
MikeDuff
Oh, and I have no speedo or Cruise. Everything else seems to be working though.
Old Jul 18, 2013 | 01:24 PM
Not exactly second gen.... but, my guess would be your rear wheel speed sensor is unplugged, or toast. Should at least solve the cruise, speedo, and ABS lites.
Old Jul 18, 2013 | 06:29 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Post your question in the 3rd gen ram forum. Could be a common problem that one of those guys will be able to help you with.
Old Feb 1, 2015 | 09:38 PM
Jasonlangan101's Avatar
Jasonlangan101
Default Wiring
I had the exact same problem everything worked but abs didn't also my 4x4 wouldn't engage I checked everything from fuses to sensors and nothing it was a broken wire in the main wiring harness that was the grief hope this helps
