School me - V10 Performance Parts
Old Sep 3, 2018 | 10:08 AM
  #31
racefan41's Avatar
racefan41
Depends on your driving style. If there are dents in the backside of your radiator, from your toenails constantly running into it, probably not much.
I would imagine gearing plays a roll in there as well. If you have tall gears in the rear (lower, numerically) probably even less, with deeper gears, likely gives you a wider margin. (tire size figures in to this as well....) I run 33's, with 4.56 gears. The truck will literally push the house of the foundation, without much effort, but, don't try and tow a trailer at freeway speeds........ I can literally WATCH the gas gauge go down. (and gas mileage DIVES DEEP into the single digits......)
Use it if you got it right? I forgot about gearing it. That as good a mod as any.
Driving habit is kind of where I thought most of it would be too.
Old Sep 3, 2018 | 10:35 AM
  #32
Murdaruss810's Avatar
Murdaruss810
Throttle body spacer does absolutely nothing on a port fuel injected motor. (aside from lighten your wallet.)
There are a fair few folks that do tuners for the V-10, I think Hemifever does, there is also a company in Livonia, (which I can't recall their name just off hand....) that will do tunes as well. As for the hardware, Jegs, or Summit have what you are looking for.
Whereabouts in Michigan?
Basicly up by Port Huron , 45 mins from The D. But traveling is no issue. I pour concrete so I'm all over the east side of the state. Basically just bought a V10 off a old company I used to work for and they neglected her bad. The owner even said and I quote oil changes are a waste of money. When I got her she was a leaking disaster and there paid backyard mechanic litterly would get wasted and just barely tighten anything down. I just did spark plugs yesterday and my Lord idk what he was thinking. Nothing was gaped. Only 2 sparkys were tight and I mean stupid tight and the rest, well I could of had my girl change them lololol I'm just trying to breath some life back in to this hog so I can pull some concrete with her again. . .
Old Sep 3, 2018 | 10:50 AM
  #33
racefan41's Avatar
racefan41
How many miles on it?
I would start with a compression test and if that's good, start running a lot of fuel injector cleaner through it. I had power issues when I bought mine even after major tune up. The injectors were a mess.
Old Sep 3, 2018 | 11:17 AM
  #34
My son-in-law does concrete. He seems to go thru trucks like water. (beer?)
So far, I haven't had any sensor issues. (knock wood.....) Hoping that I don't. Would be interested to hear how the aftermarket fellers work.
Old Sep 3, 2018 | 11:33 AM
  #35
Jimythefan's Avatar
Jimythefan
Fastman still does a ported throttle body for the V10. I have JBA shorty headers and a hemifever tuner on mine and I'm pretty happy with the way it's running now.
Old Jun 8, 2021 | 09:59 PM
  #36
uis1957's Avatar
uis1957
Default 108mm Throttle Body
Has anyone tried one of these? http://utawesomeperformance.com/stor...ttle_Body.html
Old Jun 8, 2021 | 10:02 PM
  #37
uis1957's Avatar
uis1957
Old Jun 8, 2021 | 11:26 PM
  #38
adukart's Avatar
adukart
I have the first one made. Can't really tell you how well it works as I did a cam at the same time and have had issues with that. Seems to be of good quality thus far though. Just note you need to send him an upper intake to cnc out to match the much larger opening.
