Fuel not being injected into engine
Old 07-16-2013, 09:22 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,189 Likes on 2,942 Posts
Got an analog meter? Stick it in the tan/yellow wire on the cam sensor connector (with it still hooked up) and the needle should bounce when you crank the engine.
Old 07-17-2013, 10:25 AM
QuadCabLuv's Avatar
QuadCabLuv
QuadCabLuv is offline
Do you have a set if noid lights? You could use them to verify injector pulse which would rule out the pcm and injector wiring. I would also check to make sure you have adequate fuel pressure by hooking up a gauge to the port on the fuel rail. If its a 98 or older it should be at 39 psi 98 and newer should be about 49 psi.
Since this is a new motor I'm going to assume that you had to install the distributor which means you will need to set fuel sync as well. The best way is with a high end scanner but there is a procedure on here somewhere on how to get it close without a scanner.
Old 07-17-2013, 10:27 AM
HeyYou is offline
Change over year is 96.
Old 07-17-2013, 10:28 AM
QuadCabLuv's Avatar
QuadCabLuv
Well I stand corrected.
Old 07-17-2013, 11:09 AM
Gary-L's Avatar
Gary-L
Gary-L is offline
Why is a tech question in the General section?
Old 07-17-2013, 11:19 AM
HeyYou is offline
Same reason we have general threads in the tech section, and all manner of interesting threads in the FAQ section.
Old 07-17-2013, 04:48 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
I'm thinking ground like Redneck stated.
Old 07-17-2013, 07:42 PM
GreatBears1r's Avatar
GreatBears1r
GreatBears1r is offline
Going to check all the wires and grounds again.
The its going to be towed to Dodge dealer where they will spend 8-10 hours checking everything i have previously checked, before using all that fancy equipment to locate and maybe fix the problem.
Based on their 185$$ an hour i will have a brand new 18 year old 1995 Ram 1500, empty pockets and skinned alive.
And of course i will never be told exactly what the problem was.
Old 07-17-2013, 07:59 PM
stewie01's Avatar
stewie01
stewie01 is offline
Not to get off topic but as my grandfather would say "It's the price we pay to live where we live".
Old 07-17-2013, 08:18 PM
GreatBears1r
Default Could you please define Fuel Sync ?
Not sure if i may have missed something here.
Fuel sync, im not sure if i understand that procedure.
I will tell you that when i installed new distributor, the two dots on timing gears were exactly as required and shown in tech specs.
The #1 piston was at TDC, and the rotor on distributor was exactly lined up with #1 on distributor cap.
Everything was exactly to tech specs.
I have searched for information to better help me from here, but nothing i can find hits the nail on the head so to speak.
Quick Reply: Fuel not being injected into engine
