5 speed swap / 360 swap
Old Jul 19, 2013 | 02:42 PM
5speedftw's Avatar
5speedftw
Default 5 speed swap / 360 swap
i have an auto 1500 with a 318.. im really considering a 5 speed and possibly 360 swap too.. which is better the NV3500 or NV4500? will either engine work with either tranny? also is a 4x4 so do i need a different transfer case too or should it all bolt up? thanks for the help!
Old Jul 19, 2013 | 03:18 PM
NV4500 is heavier duty. Transfer case should bolt right to it. What year is your truck?
Old Jul 19, 2013 | 03:56 PM
redneck_ram's Avatar
redneck_ram
do the 360 conversion, youll be happy you did!!
Old Jul 19, 2013 | 04:53 PM
Ham Bone's Avatar
Ham Bone
Should work with both engines.
Transfer case may have a different spline count? Nv4500 only? Maybe?
Upgrade transfer cases to the 2500 one because its supposed to be way better
Old Jul 20, 2013 | 01:19 AM
5speedftw's Avatar
5speedftw
its a 96 with a 6" suspension lift and 35's so definatly thinkin it needs some more power. thanks for the help ill try to find a NV4500 so even if i dont do the motor right away i still can later. the 4x4 doesnt work as it is (almost had me stuck earlier) so gotta see whats up with that too
Old Jul 20, 2013 | 01:01 PM
merc225hp's Avatar
merc225hp
^^^ 35's = 4.56 gears, that should be your first step before anything else.
Old Jul 24, 2013 | 01:03 AM
5speedftw's Avatar
5speedftw
hell yeah i had that in mind too. which is better cause i drive alot 4.10 or 4.56? i drive an equal mix of city, highway, country, woodland enviornments you name it.. and if i do this will my same rear work if i do either swaps? also i one wheel on the worst possible side half the time so could there be somethin wrong with my lsd?
Old Jul 24, 2013 | 09:00 AM
4.56 will keep the engine RPM where they were with stock tires.
Clutches in your LSD are probably worn out. They are rebuildable....
