engine bogging
Old Jul 26, 2013 | 06:15 PM
Tyler Springhetti's Avatar
Tyler Springhetti
Default engine bogging
would a bad oxy sensor cause my ram 1500 5.9 liter to bog when accelerating from a stop.
Old Jul 26, 2013 | 06:21 PM
dhvaughan's Avatar
dhvaughan
welcome to df.
i'd guess not.
vacuum leaks are a more common cause of a low rpm bog down that clears up under WOT.
a skip/misfire can cause a low rpm shudder that might clear up under WOT.
do you have a check engine light? codes?
post your year in your profile. (user cp) at top left in black bar.
Old Jul 26, 2013 | 06:26 PM
Tyler Springhetti
The check engine light is on and i plugged in a reader and the reader said i have a bad or circuit high voltage exhaust sensor....so i figured that was the problem but could that be something else and the vacuum would be causing the bogging?
Old Jul 26, 2013 | 06:30 PM
dhvaughan's Avatar
dhvaughan
what year? 94-95 with one O2 sensor or 96+ with 2.
and if 2, which O2 is bad? sensor 1 is front and sensor 2 is rear.
front is critical to engine tuning. rear is not.
Old Jul 26, 2013 | 06:33 PM
Tyler Springhetti
its a 2001 and and O2 sensor
Old Jul 26, 2013 | 06:34 PM
Tyler Springhetti
O2 sensor 2
Old Jul 26, 2013 | 06:47 PM
dhvaughan's Avatar
dhvaughan
it's my lowly opinion that the rear O2 sensor does not figure into the engine tuning, but only monitors the cat, and reports when the cat is not lowing the emissions. which, mine hasn't even noticed that the cat left town about a year ago...
so, i'd guess the O2 is not your primary problem. i'd check for a vac leak by temporarily capping off all the vac ports on the manifold and doing a test drive. caution - with brake booster disconnected you won't have power brakes. if it does any better, then add the vac's back one at a time to find the culprit.
if you're not familar with the plenum problem, go to the sticky threads at the top and read about it. it's both a vac leak and an oil sucking leak. are you losing oil?
Old Jul 26, 2013 | 06:55 PM
Tyler Springhetti
i just bought truck from dealer 2 days ago and discovered problem today. giving it back tomorrow so it can be repaired. I wanted to figure the problem out for myself before we gave the truck back for repair.
Old Jul 26, 2013 | 09:54 PM
Take a look down the throttle body, and see if there is oil pooling in there.
