PS Pump Fluid Recommendations
Old Aug 8, 2013 | 10:48 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Question PS Pump Fluid Recommendations
I'm curious if there is any of you that can say one kind is better than the other?
I've got the basic brand from Napa. I think it cavitates too easily.
What say you out there?
I have no mods to mine. I do have the additional factory cooler for it. I don't think everyone has that do they?
Thanks for reading ladies.
Old Aug 8, 2013 | 11:02 AM
Arde's Avatar
Arde
We went through this not too long ago. I heard that you shouldn't use ATF in Dodge power steering pumps, Merc said hes used it for umpteen years with no problems.
I'm using the O'Reilly brand with no problems.
Maybe try ATF, it's cheaper anyway.
Old Aug 8, 2013 | 11:04 AM
merc225hp's Avatar
merc225hp
Drain the system and try ATF+4 instead of power steering fluid.
Old Aug 8, 2013 | 11:38 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
I'm using a mixture of both. Used Mopar PS fluid to top off and never changed it. lol
Old Aug 8, 2013 | 03:16 PM
AtomicDog's Avatar
AtomicDog
When I installed the new Borgeson steering box, I drained out all of the old fluid, changes the hoses and went back with basic Prestone power steering fluid (clear looking stuff). My truck has the cooler, too. No issues whatsoever, once I got the air out of the lines, which took a while to complete.
Old Aug 8, 2013 | 04:05 PM
dhvaughan's Avatar
dhvaughan
here's the TSB for power steering. its very vague, and continues to list regular PS Fluid for our trucks (BR/BE). it implies that you can use ATF+4, and dodge changed over to that in later years. it says not to mix them (dodge dude).
http://dodgeram.info/tsb/2003/19-005-03.htm
Old Aug 8, 2013 | 04:26 PM
dodge dude94
My steering gear has a leak anyhow. Still works. lol
Old Aug 8, 2013 | 04:28 PM
AtomicDog's Avatar
AtomicDog
Originally Posted by dhvaughan
here's the TSB for power steering. its very vague, and continues to list regular PS Fluid for our trucks (BR/BE). it implies that you can use ATF+4, and dodge changed over to that in later years. it says not to fix them (dodge dude).
Exactly the guidance I saw when I researched this issue, so I stayed with the standard P/S fluid, even with the new steering box. Works fine in my case.
Old Aug 9, 2013 | 11:49 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Nice input guys. Thanks and I'll report what I end up doing.
Old Aug 10, 2013 | 12:43 AM
Gaius's Avatar
Gaius
I use the cheapest Napa or Autozone has in stock.
My buddy had some cavitation and bad foaming on his hydro setup, switched to Valvoline synthetic (not available anymore) and fixed it. Might try some synthetic p/s fluid.
