First post, new to me ram with timing cover leak.
Old Aug 15, 2013 | 10:45 PM
Nice.
Looks like your sidewalk could use some help though.
Old Aug 15, 2013 | 11:02 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Very nice looking Ram.
Old Aug 16, 2013 | 10:13 PM
Rpm90001's Avatar
Rpm90001
What's wrong with the sidewalk...I think you are looking at ne stairs...anyway..pulled it apart tonight,found the thurmostat housing is leaking, and the dye trails down the head in the spot I thought was leaking. I think this ma be the leak. I could not see it with everything was together.
Old Aug 16, 2013 | 10:43 PM
That wouldn't be a big surprise. Not like they aren't known for that particular trick. Throw a new thermostat/gasket in there, and retest.
You are right, I was looking at the stairs. In the pic, they look a tad crooked.
Old Aug 17, 2013 | 08:23 PM
Rpm90001's Avatar
Rpm90001
Not to happy... Yep, water neck gasket was leaking, replaced and put everything together and still have a leak. The water neck is is dry.. So I was right the first time. Has to be the timing chain gasket. I did all the hoses, PVC, thermostat,plugs,wires,cap and rotor. They were all original. Oh we'll. time for a beer. I'll just do it again.
Old Aug 18, 2013 | 11:25 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Next to the thermostat housing is the temp sensor and heater hose, could be one of them also. But, I'm sure at some point the water pump was replaced. And if it was, it is very common for the TC cover gasket to get torn if the WP was not carefully removed. You can try tightening all the bolts on WP and TC cover. Might get lucky.
Old Aug 19, 2013 | 08:41 PM
Rpm90001's Avatar
Rpm90001
Zman17
Thanks, both the temp sensor and heater hose are dry. I confirmed the cover gasket was bad. Water pump was original.
I have a few Question now that it is apart.
1) As for replacement parts, who do you all use. I need to get water pump, timing chain,gaskets, cover seal. I don't want to order them. My choices are napa, auto zone,advance auto, car quest.
2) re installing the cover do you use just use the gasket only? Or sealer and gasket. I always use the 3m black. I have always used it on subaru's. sealer or dry?
3) Cover came off the pan with no damage, Just clean and reinstall? Any sealer?
My sound like silly questions.. But this is my first dodge. Have done many sb fords and subaru's. I've learned to ask first..makes my life much easier.
Also,what's the safest way to turn the motor over to line timing marks when it's apart. I was just going to add a few large washers to the crank and use the crank bolt to turn it over. Tips on replacing he chain always welcome.
Thanks for the help.
G
Attached Thumbnails First post, new to me ram with timing cover leak.-th_c3fa234843cea834f7c4aa54e37b8417_zpsae048c36.jpg
Old Aug 19, 2013 | 09:33 PM
stewie01's Avatar
stewie01
Zman17
G
If you're replacing the timing chain simply slide the old one off, the chain and sprockets will slide off as one piece. DO NOT turn anything once the chain is off.
Assemble the new set and slide it on, it may be a little tight but it will go on....
Old Aug 19, 2013 | 09:49 PM
Rpm90001's Avatar
Rpm90001
Thanks...don't know what I was thinking. It's already in position...thank you.
Old Aug 19, 2013 | 10:23 PM
I don't like auto zone, and frequently go to Advance. The folks there know me on a first name basis.... (which isn't necessarily a good thing...... )
I got the SA Gear timing set. (double roller, .25 inch pitch) Been on the truck for a while now, no issues.
I use the RTV ultra black sealant. I just used some around the coolant ports between the block, and timing cover, and all the way around the outside of the water pump. No leaks. (at least, not from there....)
When reassembling the cover, start the pan bolts first, and leave them loose, get a couple of the lower timing cover bolts started, and then put on the pump. The problem you run in to when tightening them is, you are trying to seal in two different directions a once...... I elected to press down on the cover, and tighten the bolts.... didn't want to chance a leak at the coolant ports... (I had the pan bolts snug, but, not tight) No leaks there for me. (so, it worked....)
Have you done your plenum yet? Most of the stuff you already have off, also has to come off to do the plenum...... no better time than the present, if you haven't already.
