First post, new to me ram with timing cover leak.
Old Aug 19, 2013 | 10:27 PM
  #21
Rpm90001's Avatar
Rpm90001
Plenum has not been done yet. I did look inside, and no oil our symptoms yet. I'm considering it. Looking more into it..
Old Aug 19, 2013 | 10:32 PM
  #22
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
You've already got a ton of stuff off....just depends on how long you want to have your truck down.
Old Aug 22, 2013 | 05:34 AM
  #23
Rpm90001's Avatar
Rpm90001
Well all back together...over heati g and leaking at the o ring. I think I have air in the system. It was too late to really look into it. I did not burp it, I'm sure it's my issue. Everything went good. I will look into it after work today..
Old Aug 22, 2013 | 09:18 AM
  #24
Leaking at which o-ring? The one for the heater hose? If so, those are available (whole pipe, with o-ring.) at the local parts store in the "Help" section.
Need to burp it as well. You most likely have air trapped below the thermostat.
Old Aug 22, 2013 | 04:26 PM
  #25
Rpm90001's Avatar
Rpm90001
Yes, it was leaking at the pump o ring. Easy fix..I broke it putting it in. It was a new pipe and ring. My timing chain gasket keme with a new one also, so I had one in stock. Burped the system and all good. Long ride, no leakes, runs great, stayed cool and its hot today. Only distilled water and a tiny bit of antifreeze in there now. When I'm sure of no leaks, I will do 50/50.
Thanks for the help..now on to the non working A/C
