AC cold, then not so much
Old May 26, 2014 | 09:03 PM
  #21
On the side of the can, should be a little table, that relates low pressure side (with compressor running) with ambient temp. Have a look at that, and see how it relates to your situation, take it from there. Overfilling the system will make it do that too. Just the high pressure switch cuts out the compressor, instead of the low.....
If it was also rather humid out, your pressure is right in the ballpark. If not, then you are a bit high. (I looked up a chart. )
Old May 28, 2014 | 11:56 AM
  #22
krs7272's Avatar
krs7272
Drove home from work a/c worked for 20 minutes then stopped. Came on 10 minutes later for 2. Pulled high pressure switch connecter did nothing. So for some reason clutch engages but then stops.
Old May 28, 2014 | 01:27 PM
  #23
Need to see what pressures are doing when it decides to quit. Hi and low side.
Old May 28, 2014 | 05:07 PM
  #24
krs7272's Avatar
krs7272
Need to get ahold of some gauges. Though drove home today was cooler out about 65 and a/c worked nonstop. And showed the correct pressure at least low side. Compressor didnt cycle and pressure stayed constant. Is the compressor supposed to cycle or just stay on?
Old May 28, 2014 | 07:14 PM
  #25
For the most part, it just stays on. Some cycling isn't unusual, it's when it starts cycling every few seconds that you know you have an issue.
Old May 28, 2014 | 07:20 PM
  #26
krs7272's Avatar
krs7272
Ok. I originally filled the system after replacing the evaporator and dryer etc a couple years ago. Since then it always cycled on and off Id say every 10-20 seconds so wasnt sure what proper operation was.
Old Jun 21, 2014 | 02:19 AM
  #27
dustin.bunton's Avatar
dustin.bunton
Sound a lot to me like the air door under the passenger side by the air vents the actuator has a plastic joint to the metal doors and more than likely that's broken heater treater has a metal replacement for $25 will never brake again I didn't believe it at first on mine it took the actuator off spun the doors open then boom cold air heater treater has videos and fairly clear instructions iv tried clutch lines condenser refrigerant everything I could think of and felt pretty retarded to find out a piece of plastic not even an inch long killed my ac if you need more info on it just ask
Old Jun 21, 2014 | 03:03 AM
  #28
krs7272's Avatar
krs7272
Fixed my issue a week ago. Traded my 2001 in and got a 2014 Big Horn.
Old Jun 21, 2014 | 09:49 AM
  #29
dustin.bunton
Good fix
