Possible bad PCM
Old Mar 21, 2014 | 05:02 PM
  #51
bgmins's Avatar
bgmins
Checked for spark, no spark.
I have two coils and both test good.
Checked power to coil with relay in place and got batt voltage for maybe half a second.
I then jumped the terminals for the asd relay and got constant power to coil but still no spark.
Old Mar 21, 2014 | 05:41 PM
  #52
Crank sensor.
Old Mar 25, 2014 | 08:55 PM
  #53
bgmins's Avatar
bgmins
Got new oem crank sensor still spark.
p0351 is still showing.
Old Mar 25, 2014 | 10:04 PM
  #54
Hhhhmmm...... You are getting spark, but still getting the code? Cam sensor? (at least its cheaper......)
Old Mar 26, 2014 | 07:50 PM
  #55
bgmins's Avatar
bgmins
Meant to say still no spark.
I thought faster than I was typing.
Old Mar 26, 2014 | 07:53 PM
  #56
Do you have power at the coil? (if the engine isn't turning, you will only have power there for a few seconds after the key is turned to "on".)
Old Mar 26, 2014 | 08:15 PM
  #57
bgmins's Avatar
bgmins
I didn't check it while the engine was turning, I'll have to check it tomorrow.
But I did have constant power to coil when I jumped the asd terminals, and I tried starting it and nothing.
Old Mar 26, 2014 | 10:34 PM
  #58
Have you replaced the coil yet?
Old Mar 28, 2014 | 08:30 PM
  #59
bgmins's Avatar
bgmins
Coil is new and tests good.
Got somebody to help check voltage while engine is turning.
I get batt voltage for half a second, then saw a constant 1.6v before trying to start, then while turning over saw 11.8v but drops to 10.8v and stays there while turning.
Old Apr 4, 2014 | 06:57 PM
  #60
bgmins's Avatar
bgmins
Bump.
