5.9 Running Hot when first drove
Old 08-26-2013, 10:55 PM
COL's Avatar
COL
COL is offline
Default 5.9 Running Hot when first drove
It seems like every morning when I first drive my 96 Ram with the 5.9 for the day the temp climbs all the way up until about 210-220* then drops after maybe 30sec to a minute down to 180-190. My truck has a 180* T-stat in it with a newer water pump and I know there is no more air in the system. Also yes there is the proper amount of coolant in it. It never hangs in the 210-220 range, it always drops. Should I just accept this for how it is? I guess I just never remember it doing this before I did a complete engine rebuild. Other than that it runs like a top.
Old 08-27-2013, 12:26 AM
dodge dude94's Avatar
dodge dude94
dodge dude94 is offline
Banned Goober Smoocher
Me thinks the t-stat might be a tad late to open.
Old 08-27-2013, 11:38 AM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Why do you have a 180 t stat in your truck? If you have no mods to support it, install a 195 Stant super stat. You'll might get a little better MPG's.
Old 08-27-2013, 10:43 PM
TheBigRedTruck's Avatar
TheBigRedTruck
TheBigRedTruck is offline
My 5.2 goes to 210 when first driving then hovers between 194-198. I have a 195* stat. I think its normal.
Old 08-28-2013, 12:46 AM
95' 360 Ram's Avatar
95' 360 Ram
95' 360 Ram is offline
I had the same experience after installing a new water pump on my truck, I wouldn't worry to much. I ended up changing to a 180* t-stat after the 195* went 3/4 the way to overheating from how hot it gets where I live.
Old 08-28-2013, 01:07 AM
ReadRam's Avatar
ReadRam
ReadRam is offline
It 's not normal, even when outside temperatures are high. T-stat is opening late most likely. Air in the system and bad radiator caps can make engine run hotter by 10 to 20 degrees, but will stay up in the 210 to 220 range and not drop to normal.
Old 08-28-2013, 11:34 AM
LoneWolfArcher's Avatar
LoneWolfArcher
LoneWolfArcher is offline
Check coolant level. This is a classic sign of low coolant.
Old 08-28-2013, 02:48 PM
chromed95's Avatar
chromed95
chromed95 is offline
Mine does this as well. A few years ago it was working just fine. Then the thermostat got stuck open so I had to change it. The new thermostat did this exact symptom but I didn't worry too much about it. When I did the plenum I threw in the thermostat from the hughes kit (180) and it got stuck open as well. So I changed it out for the 195 again and it still goes way past 195, then cools down to normal operating temp on the initial warmup. Thought I had all the air out. I would like to know what you do to fix this as well.
Old 08-28-2013, 10:56 PM
diverjer's Avatar
diverjer
diverjer is offline
MY 1996 5.9 always runs a tad above the center 200 degree mark, might get to the center of the second 0 of the 200 degree number on 100 degree + days, slow driving with A/C cranked up. Doesn't go near the red area of temp gauge. Always 200 or above, winter, summer, A/C on. Don't know how you can tell if is 210 or 220 as I don't have those numbers on gauge. I have new cap, no air in fluid and it is full.
Since that is normal for this truck, I don't worry. I would only be concerned if it was getting out of range of what has been normal for what I am use to seeing.
Old 08-28-2013, 11:42 PM
dodge dude94
Mine runs 1 needlewidth under the 210 mark.
I feel like it's too warm, but I don't get spark knock, so meh.
Quick Reply: 5.9 Running Hot when first drove
