3 pin or 8 pin?
Old Feb 11, 2018 | 04:17 PM
TheMadCanadian's Avatar
TheMadCanadian
There are still electronics even in the RH trans. TCC, and O/D are electrically controlled. That is all you will find on the RH versions, so, you only need three wires. Power, and control circuits for the two solenoids.
from Sonnax and TransGo , RH only had the O/D is electronically controlled. not the TTC.
they're probably wrong , but in a junkyard i remember seeing a 94 ram 46RH and there was only 2 wire in the tranny wich was for the O/D. red and black wire.
Old Feb 11, 2018 | 04:21 PM
TCC is solenoid controlled as well, by the PCM. Not sure where Sonnax and Transgo are getting their info...... 94 and up RH transmissions should have three wires. (the 42 may be different......)
