5.2 magnum won't start
I have a 2001 dodge ram 1500 5.2 and it won't start. So, here's the issue I just rebuilt the engine truck sat for over a year with no battery. The computer was a week old when the old engine blew. I made sure my timing marks matched up. The distributor is aligned properly and it has a new pickup, cap, rotor, plugs, wires, and crank sensor. All the internals are fresh. All the valves loft as they should I pulled the valve cover and rotates the engine to check. Spark is strong and the timing light shows it's dead on. All it does is crank and crank won t start. I drained all of the old gas out put new gas in and the fuel pressure is right on the money. Compression is at 120 on all cylinders with a little compression bleed which should be normal with unused rings. Could the computer lose it's flash or memory from sitting without power. It is pulling a code for the o2 sensors but they havnt been in the exhaust since I bought the truck in 2013. Anyone else have any ideas. All the sensors are connected as well and all the ones on the intake sat inside the truck untouched during the rebuild.
It shouldn't lose its programming no matter how long it sits. The program is literally flashed into the chips memory and exists there until its changed. You could even take the chip and sand it down and see exactly how it is programmed(Expensive machines only a few college have for research purposes :P) So no, If the computer was at fault, it would've been from shorting or poor connections, not program loss. I cant imagine what would be wrong with it if spark is good and so is fuel and the timing.
You seem to have checked all the common things I would tell you to check. Its extremely odd that you would have fuel getting in, a good spark, engine crank, and not have ignition. When I swapped an engine into my truck ( not even the same engine size that came out) it started right up after second attempt even on ~year old gas after about 25 seconds of cranking, then started immediately on second key turn.
Also, do you know why the other engine blew? Did you ever find out why?
Have you verified you have injector action? I don't see that in your list. On a carb engine, I'll often spray started fluid into the air intake to see if it'll fire. You could try that, but I'm not sure how that works with the intake on that 318.
Thanks. I tried both starter fluid and gas. It's a crank, no start. There's no spark and no fuel pump.
Trending Topics
