A Few Questions
Old Sep 1, 2013 | 09:42 PM
clsoonersfan22's Avatar
clsoonersfan22
Default A Few Questions
Ok, so a few days ago, I went out and bought a 1997 Dodge Ram 1500 5.9L 4x4. Pretty much got a steal on this, anyway a few questions about fixing a couple of things.
1. The cruise control wont work, the light does come on but it wont engage. I did a little research and found out that most likely its a vacuum line under the battery holder that is causing the problem. I havent had time to pull the battery/holder yet but will tomorrow. My questions if its not the vacuum line that is causing it what else could it be? I want to make sure I get this right tomorrow so thats why I am asking now.
2. Ok so when I put the truck in 4x4 the light wont come on saying its in 4x4 mode. Is there a way I could make sure the 4x4 is working correctly? Also how would I go about fixing that light to make sure it works?
3. So originally i wanted a little newer of a dodge but since I got a steal of a deal on this one, I jumped all over it. Anyway one thing I hate about 97 and older dodges is the chrome mirrors. My questions is if I bought say like a 01-98 dodge mirrors, would they be able to fit the '97?
So I thinks thats it for now but I just wanted to say thank you for this forum. I know just about the basics of truck but I am still learning about it. I will more than likely have more questions when I come to them. Thanks!
Old Sep 1, 2013 | 10:26 PM
AtomicDog's Avatar
AtomicDog
With regard to question #3, I swapped my chrome power mirrors out and replaced them with power towing mirrors. Here is a link to an example:
http://www.ebay.com/itm/94-97-DODGE-RAM-POWER-Towing-Tow-Hauling-Side-View-Mirrors-PAIR-/400565127140?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d438ac7e4&vxp=mtr
Old Sep 1, 2013 | 10:42 PM
Matt Nickerson's Avatar
Matt Nickerson
1. If the cruise just flat out doesn't work, it's likely the vacuum line. Not sure what else it would be.
2. Does the 4wd light come on during the bulb check? If so, read here: http://dodgeram.org/tech/repair/4X4/4x4_engagment.htm If not, replace the bulb.You should be able to just tell whether or not your in 4x4.. Mark the front driveshaft as reference point, kick it in 4wd, and drive a couple feet; if the point moved you have 4wd. Or you can just turn hard on dry pavement (at very slow speed) and your wheels will jump.
3. Paint your mirrors black or get tow mirrors. 98+ wont fit.
Old Sep 1, 2013 | 10:52 PM
Ham Bone's Avatar
Ham Bone
Or you could find some grass (preferably not your neighbors lawn) and floor it. If you spin your bak wheels and destroy the grass you're not in 4x4
This is the reccomeneded way
Also, cruise not working could be back speedo sensor. But you're pre 98 so that may not be the case
Old Sep 1, 2013 | 11:02 PM
clsoonersfan22
Sweet! thanks for that website as well as the tips. Havent been able to run a bulb check on it yet, will do that tomorrow. Im praying its something electrical. As for the mirrors, thanks for letting me know my drivers side mirror is being held on by some mechanical screws right now. So it looks like my next purchase will be going towards some towing mirrors.
Old Sep 2, 2013 | 12:08 AM
AtomicDog's Avatar
AtomicDog
If you are going to purchase towing mirrors, be sure to get the added brackets, as they are required to mount/stabilize the extra weight of the towing mirrors. Here's a link to an auction for the mirrors and the brackets:
http://www.ebay.com/itm/94-97-Dodge-Pickup-Truck-Power-Towing-Mirrors-w-Brackets-Right-RH-Left-LH-Set-/130946544271?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e7d05b28f&vxp=mtr
Old Sep 2, 2013 | 01:43 AM
clsoonersfan22
94 97 Dodge Pickup Truck Power Towing Mirrors w Brackets Right RH Left LH Set | eBay
Sweet thanks so much for the link. I appreciate it. Will order some next payday for sure.
Old Sep 2, 2013 | 08:07 AM
Matt Nickerson
Just know you'll catch a lotta flack for driving with your tow mirrors flipped up with no trailer
Old Sep 2, 2013 | 09:39 AM
Wasn't there an ad for someone selling their ghost trailer? Maybe he could pick one up?
Your cruise and 4x4 issues are more than likely related. Both are vacuum operated. A big enough vacuum leak, and neither will work.
