Hughes FI Airgap Install Thread
These are the clamps I used in this kit, the small black ones that that use an 7.5mm or slotted screwdriver. https://shop.advanceautoparts.com/p/...rm=hose+clamps
Thanks for the replies guys.....
I bought some from O'Reilly's. Advanced was out.
Got 5/16" Fuel injection lines, and fuel injection clamps. Was told by Hughes that they use the "old school" European clamps. They have rolled edges so the clamp actually clamps without cutting into the line...
These here.....5/16" fuel line
And clamps....Clamps
Probably could have got the 1/4" size to go on the barbs as well... but wasnt sure if the smaller I.D. might not allow enough flow...
Not sure if I trust them but we'll see...
Thanks again....
Thanks again....
Sorry about the OT but I've been wondering about an easy swap to OBD2 for years... Is there any chance having a 95 with manual gets me around the problem and a newer 5 speed pcm could be adapted without throwing codes? What would be needed to do a conversion...wiring harness and computer from a 96 with 5 speed?
You need to get the Engine and tranny Wiring harness, dash Wiring harness and computer from either a 96 or 97 truck (which is cheaper) or send your harness out to Performance Injection Equipment and have them convert it to OBD2 and send you that back with a computer but don't recommend that as it is to expensive, it's $2000 to have them do it. I bought a complete Wiring harness front to rear including the dash and computer from a guy in Connecticut for $335
Not sure you actually need the dash harness, should be able to just repin some of the connectors to include what is already there. There really wasn't that much difference between the 95 and 96-97 interior harness in any event. Not sure which would be easier though.
