Hughes FI Airgap Install Thread
Old Sep 13, 2013 | 09:45 PM
  #21
merc225hp's Avatar
merc225hp
Originally Posted by Spillage
lbs is lbs/hr, and cc is cc/min, both are volume delivered over time at a specific supply pressure... one an imperial designation, one is metric.
Can you expand on your comment please?
Best as I can, not all 24lbs injectors flow the same cc's, cc's is a more precise way to read what the injector is delivering for fuel. For most an injector upgrade is not needed if you use a tuner, I changed injectors because I had a lean spot mid range and do not use a tuner. Stock injectors are good to 450+hp if a tuner is used. I was into this many years ago I still have some info on this but Drewa is the man when it comes to injectors for these trucks
Old Sep 13, 2013 | 10:38 PM
  #22
Spillage's Avatar
Spillage
This would be true is you look at "24lb injector" as a generic size.
A 24lb injector could conceivably be anything between 23.5lbs/hr and 24.5lbs/hr (a 10.5cc/min range).
When tested injectors are noted to 1 or 2 decimal places of a lb/hr... 0.1lb/hr is about 1cc/min, so the accuracy of using imperial or metric notation is in the same ballpark.
And since the ECM is capable of allowing for a range of injector flow rate (though all 8 should be matched), the difference between an injector selected by either imperial or metric designation is insignificant as far as the ECM is concerned.
Old Sep 14, 2013 | 01:42 AM
  #23
merc225hp's Avatar
merc225hp
Post deleted.
Old Dec 2, 2013 | 09:43 PM
  #24
Spillage's Avatar
Spillage
As an update to my earlier post (post #9);
I just recently got the LT's and 3" exhaust fitted (without cat, as there wasn't room).
The new exhaust system has improved the lower RPM acceleration that was in question with the intake install.
This improvement also carries through the higher RPM ranges as well, so over 2000 RPM it's really coming together nicely for a little engine.
After a couple of tanks to see how the MPG's are going, I'll up the octane and tune to 97 and see how that goes.
Old Dec 2, 2013 | 10:14 PM
  #25
lastrights's Avatar
lastrights
I had the airgap on my ram loved it so much I sold it with the truck and used some of that money and bought one for my 5.9 Durango !kegger sucks !
Old Apr 30, 2019 | 06:09 PM
  #26
Gary Benoit's Avatar
Gary Benoit
Default Hughes FI Airgap Intake Manifold
I have a 1995 Dodge Ram 1500 4x4 5.9L Magnum 360 and have purchased this Intake and was wondering if anyone has installed it and did they have any issues
Old Apr 30, 2019 | 06:39 PM
  #27
Only real problem is what to do with the fuel crossover hose at the back of the fuel rails. Injectors are closer together on the airgap, so, that tube needs to be shorter. Kit should come with the right stuff, though, some have not had luck with the hard plastic tubing, and just gotten fuel injection hose, and hoseclamps instead. Aside from that, pretty straightforward. Be sure and use NEW intake bolts.....
Old Apr 30, 2019 | 08:01 PM
  #28
Gary Benoit
I will be using the new Intake Manifold bolts, was just curious if anyone installed this Intake on 1995 5.9L Magnum 360 and did it go smoothly or was there any issues
Old May 1, 2019 | 09:24 AM
  #29
Does the manifold have provision for EGR valve? That's the only real problem I could see, and from past history, it doesn't really seem to be that much of an issue. The PCM may or may not whine about the lack of EGR......
Old May 1, 2019 | 10:00 AM
  #30
Gary Benoit
The original Intake has the EGR and I'm eliminating that when this new Intake goes in
