No Bus, Brake Light
Old Sep 17, 2013 | 08:23 PM
ShelbyGT550's Avatar
ShelbyGT550
Default No Bus, Brake Light
About every couple days sometimes more the cluster will go out and flash "no bus" Replaced the speed sensor and I have verified its not the speed sensor as cruise stays on and maintains speed while the dash does its "no bus" thing, Its starting to get annoying as its not recording my mileage while its doing this. Another issue is that the brake light is on all the time, I have checked the parking brake, Replaced all the brakes all around, Front calipers as well, And it still won't go out, Fluid is at max. I have looked all over the forum with no info to my problems, Thanks in advance,
Its a 1999 Dodge Ram 1500 5.2, 4X4, Auto,
Old Sep 17, 2013 | 08:36 PM
ShelbyGT550
Also forgot to mention, A couple days ago, While accelerating I had the "check engine" light come on and flash at me until I got my foot out of the gas, Any ideas?
Old Sep 18, 2013 | 11:33 AM
CEL flashing is indicating an engine miss. Fixed your plenum yet?
No bus may simply be a bad connection to the cluster. Do any of your gauges quit working when it comes up?
Old Sep 18, 2013 | 12:11 PM
ShelbyGT550
Have not replaced the plenum yet. First the spedo goes. Then the tach. Then the rest go
Old Sep 18, 2013 | 01:29 PM
Johnn123's Avatar
Johnn123
Open up the pdc box, and tighten the big screw at the top towards the motor down. When it gets tightened down as far it will go it will feel like its stripping but its not, just prevents it from over-tightening. Doing this, and cleaning my grounds up solved the no-bus issue when I got it.
Old Sep 18, 2013 | 05:06 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Multiple misfires most likely means cat is clogged or clogging. Fix the plenum before you have a cracked head or 2. The other problem is secondary as far as cost in the long run.
Old Sep 18, 2013 | 08:38 PM
ShelbyGT550
Ok, I'll take a peak at the plug on cyl 8 and look down the intake to see what I see, I'll also tighten that bolt that was suggested. But what about my brake light? Any ideas on it,
Old Sep 18, 2013 | 08:46 PM
Could be related to the cluster fark. (sorry, couldn't resist) When you lose speedo, ABS gets confused.
Old Sep 19, 2013 | 09:11 PM
ShelbyGT550
Here is what I see when I look down the intake
And Cly 8 Plug
Attached Thumbnails No Bus, Brake Light-20130919_200249.jpg   No Bus, Brake Light-20130919_195908.jpg   No Bus, Brake Light-20130919_195853.jpg
Old Sep 19, 2013 | 09:12 PM
ShelbyGT550
Also cleaned and replaced a bunch of the grounds, and the connections in the PDC, Time will tell if it fixes that problem, Brake light is still on tho.
