AC compressor clutch noise???
Old Sep 21, 2013 | 04:30 PM
Nsmitty21's Avatar
Nsmitty21
Default AC compressor clutch noise???
For a few days now my truck has been making a noise coming from the serpintine belt that comes and goes. It is getting worse and now sounds kind of like what a brake sound like when the pad is gone and its metal on metal. It sounds like it might be the ac compressor but it's hard to tell for sure. Although it does get better when I turn the AC on. But sometimes it comes and goes even when the AC isnt on. Has anyone else run into this problem? If it is the compressor, im guessing it's the clutch. Can you just replace the clutch? Is it a tough job?
Old Sep 21, 2013 | 04:41 PM
Just discussed:
https://dodgeforum.com/forum/2nd-gen...ompressor.html
Old Sep 21, 2013 | 07:54 PM
Ramman18's Avatar
Ramman18
It could be related to the AC clutch but check the cheaper parts first. The belt is the first to wear out and checking for cracks is "old school" thus no longer accurate. The belts today wear down in the grooves and don't show signs of wear. Here's what I would do:
Remove belt and check all the pulleys/bearings for play and ease of spool.
If all checks out, replace the belt first and then if it persists, replace tensioner and idler pulley before something more expensive. Narrow it down cheapest to spendy. If you are positive it is the AC clutch, I would replace with a rebuilt compressor than mess with just the clutch.
Old Sep 30, 2013 | 11:08 AM
BackInBlack43's Avatar
BackInBlack43
i recently had a similar problem and changed my a/c compressor. If you wind up getting to that point its not that hard of a job at all. took me about an hour and a half and i had never done one before.
Old Oct 1, 2013 | 10:12 AM
Nsmitty21's Avatar
Nsmitty21
Oh yeah? The only thing that worries me is the whole vacuuming out the system. I know I can replace the part, I just want to make sure it works after. I found it is the clutch pulley bearing and I bought a different belt to bypass for now until I decide what to do. I think it might be easier to replace the bearing and leave the compressor as is.
Old Oct 1, 2013 | 10:14 AM
You can get just the clutch and such. Don't even have to crack open the system. Think they are on ebay, couple threads around here with links.
Old Oct 1, 2013 | 10:21 AM
Nsmitty21's Avatar
Nsmitty21
Yeah that is what I am leaning towards right now. I see on ebay you can buy the clutch, bearing, and the magnet thing in a kit. I read the threads and it doesn't look too hard. Sounds like getting the first little nut off is the hardest part. I would be much more comfortable not cracking the system.
Old Oct 1, 2013 | 10:50 AM
ThisIsChallenging's Avatar
ThisIsChallenging
There's some helpful information about it here
https://dodgeforum.com/forum/2nd-gen...dodge-ram.html
Old Oct 3, 2013 | 12:00 PM
BULLRAM's Avatar
BULLRAM
Its not hard at all, the nut comes off real easy, the small tricky part ,which really is not bad either is to get the c-clip off of the magnet, you need straight c clip pliers the c-clip is about 2 inches or more, clutch comes right off or a little tap, no freon loss at all.
Old Oct 3, 2013 | 12:38 PM
BackInBlack43
all the freon in my system had already leaked out so i didnt have to worry about that lol. but i cant imagine just the clutch being hard to do either.
