Add Power to 5.2 Liter Magnum
Old Sep 23, 2013 | 02:06 PM
ChillyPhil's Avatar
ChillyPhil
Originally Posted by mantisman51
Sell it and buy a Cummins. Seriously, though, short of a turbocharger or supercharger, nothing will make a big difference. If you like your V8's in tiny little pieces, go with either of those. These 318's are good ol' workhorses, but never were meant for high performance. The 360 gets a lot worse fuel economy and barely more power; ergo: Cummins.
AMEN. I have a lot of stuff done to my 5.2 and it still doesn't please me. Maybe with different gears or more motor work done, but you might as well get a cummins. When my Ram dies, I plan on getting a 2nd gen cummins if I can find one that isn't beat to crap.
Old Sep 23, 2013 | 03:26 PM
Ham Bone's Avatar
Ham Bone
IMO 360s are worth heavily modding. I mean who wouldn't want a 408? But 318s you just don't have enough to work with if you wanna stay natural induction.
Old Sep 23, 2013 | 05:13 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
IMO, they sound better too.
And yes, stock for stock, I can tell the difference between the 318 and 360 Magnums.
Old Sep 24, 2013 | 02:05 PM
ChillyPhil's Avatar
ChillyPhil
How much change do you have to do to fit a 360? Exhaust the same size and everything?
Old Sep 24, 2013 | 02:25 PM
Johnn123's Avatar
Johnn123
Its the same motor aha. 360's are externally balanced while 318's are internally balanced (i got that the right way right?). Just need a flex plate for the 360 to swap it over. 360's aren't really that much worse on fuel, and it has 20 more HP and about 80 ft/ibs more of torque. Exhaust should be the same really.
Old Sep 24, 2013 | 02:30 PM
dodge dude94
Yep. Everything is an easy (LMAO) swap, flexplate mostly. Just remember that the 318 PCM will make the 360 run lean.
Old Sep 24, 2013 | 04:20 PM
ChillyPhil's Avatar
ChillyPhil
I'm just going to build my puny 318 haha. Then get a Cummins later.
Old Sep 24, 2013 | 04:27 PM
getdown78's Avatar
getdown78
I used my 360 harmonic balancer on the 318 i put in mine is that ok ?
Old Sep 24, 2013 | 04:46 PM
No. You will end up with bearing/crankshaft failure from the vibration that will cause.
Old Sep 24, 2013 | 07:53 PM
getdown78's Avatar
getdown78
Then why are the part #s the same ?
