Add Power to 5.2 Liter Magnum
#31
Me, myself, & I have always liked stroking an engine as it really helps with the amount of torque the engine can put out.
#32
How are you making the walls thinner when you stroke the engine? I'm not following you on this. Same thing with forced induction? I didn't know doing these things would make your cylinder walls thinner. Guess I learn something new everyday.
#33
#34
#35
I knew what you were talking about was being sarcastic and fooling with ya.
![Icon Naughty](https://dodgeforum.com/forum/images/smilies/icon_naughty.gif)
Do you know what the maximum effective range of an excuse is ? I post all the time at 2AM cause I can't sleep many nights and I got to have something to do so I surf all my forums.
Got some new parts for the engine yesterday, just little stuff for dress up. I like to play dress up all the time with my Jeep. I'm coming out of the closet I guess.![Icon Special](https://dodgeforum.com/forum/images/smilies/icon_special.gif)
![Icon Crackup](https://dodgeforum.com/forum/images/smilies/icon_crackup.gif)
![Icon Laugh](https://dodgeforum.com/forum/images/smilies/icon_laugh.gif)
#36
Despite the apology let me set it straight since a stroker is something many don't understand. You get more displacement from a stroker but not because it's been bored. A stroker kit has a crank that has a larger stroke hence the name stroker. The piston then has a larger travel/stroke making it so you need shorter rods and or pistons. This gives you a bigger displacement and a higher compression ratio. The higher compression ratio is the reason you wouldn't want to go forced induction without doing something to lower the compression ratio like larger heads, shorter rods or pistons.
#37
