problems with nv3500 5 spd
Old Oct 1, 2013 | 11:19 AM
zellj2011's Avatar
zellj2011
Question problems with nv3500 5 spd
i just bought a 2000 1500 4x4 5 spd. it wasnt the prettiest truck by any means but i have problems coming from the trans. sounds like constant grinding/vibrations, but it shifts fine and none of the gears have an obvious problem. it has 173xxx miles, is there something i need to replace like throwout bearing maybe? i have no clue at all. and any suggestions on headers, i need new and havent looked at what works good for the rams.
Old Oct 1, 2013 | 11:28 AM
Ham Bone's Avatar
Ham Bone
I'd check the t-case, u joints and the like.
Does it seem to actually come from the teams itself or just the drivetrain in general?
Old Oct 1, 2013 | 12:13 PM
zellj2011's Avatar
zellj2011
from the tranny itself. when i push clutch in the sound dulls some, and you can feel the vibrations in the stick
Old Oct 1, 2013 | 12:22 PM
Brandon Thomas's Avatar
Brandon Thomas
Does it do this when your not moving?...ifso
Old Oct 1, 2013 | 12:24 PM
Brandon Thomas
Does it do this when your not moving?...if so i would say either pilot bearing or throw out bearing.
Old Oct 1, 2013 | 12:25 PM
Brandon Thomas
Sorry about the double post
Old Oct 1, 2013 | 12:45 PM
Ham Bone's Avatar
Ham Bone
They are known to rattle a little bit, it is a truck tranny after all
Old Oct 1, 2013 | 03:36 PM
zellj2011's Avatar
zellj2011
i understand the rattle a little ham, but this isnt a little. and yes from the second it starts until i shut it off brandon.
Old Oct 2, 2013 | 10:46 AM
Check fluid level, and if it even has the right fluid in it.
