Thick white smoke from exhaust
Old Oct 4, 2013 | 09:02 AM
dynalow93's Avatar
dynalow93
Default Thick white smoke from exhaust
Immediately following a DIY ball joint replacement, I started my '01Ram 1500, 4x2, 5.2 l for a test ride and thick white smoke began pouring from exhaust. Coolant level normal and oil looks good. No sign of bubbles or air in radiator. Did a compression test and #1 cyl = 160 psi, #7 = 150 psi and all others were 175-180. Not sure how to interpret those readings since low cylinders are not adjacent???? Any and all suggestions are welcome.
Old Oct 4, 2013 | 09:30 AM
Does it clear up after a bit?
If it continues to smoke, you probably have a blown head gasket.
Start with the engine stone cold. Fire it up, and then immediately check the upper radiator hose, and see if it is pressurized, if it is, that's a sure sign of blown gasket.
Not just water in the gas is it?
Old Oct 4, 2013 | 10:15 AM
dynalow93's Avatar
dynalow93
I followed your advice and the upper hose stayed unpressurized after cold startup. Someone suggested that sitting with front end jacked up for 7 hrs while changing ball joints could have allowed sludge, water, etc now to the fuel pickup. ???? No performance issues...runs great. Any other thoughts?
Old Oct 4, 2013 | 10:57 AM
Has it cleared up?
Old Oct 4, 2013 | 11:41 AM
AtomicDog's Avatar
AtomicDog
Drive it like you stole it and I suspect it will clear up.
Old Oct 4, 2013 | 12:29 PM
dynalow93's Avatar
dynalow93
I did just that...drove it like I stole it...and it cleared up. Now I know...having the front end raised up for 7 Hrs changing ball joints allowed all that oil to flow to the rear and get on top of the pistons. They are lubed now! Thanks all.
