5.2 exhaust
Old Oct 9, 2013 | 12:22 AM
TheBigRedTruck's Avatar
TheBigRedTruck
Default 5.2 exhaust
I was wondering if I removed my muffler and just left it open from where it got taken off if there are any cons to doing this. I have EGR removed and opened at the intake and exhaust, so my exhaust is already loud and sounds carbureted when started up first time. I still want to keep my bottom end torque, all of it actually.
Old Oct 9, 2013 | 07:58 AM
EGR is opened up? Could you go into a bit more detail on that?
Old Oct 9, 2013 | 10:17 AM
TheBigRedTruck
the tube that connects the exhaust to intake is cut at both ends, so the exhaust has a half inch hole in it and the intake as well (with a filter on the intake so no dirt gets in)
Old Oct 9, 2013 | 10:30 AM
80Adventurer150's Avatar
80Adventurer150
You should plug both ends.
Old Oct 9, 2013 | 10:33 AM
TheBigRedTruck
but its so loud with it unplugged, its like I have a cummins under the hood! at idle it rumbles
Old Oct 9, 2013 | 10:41 AM
80Adventurer150
very good.
Old Oct 9, 2013 | 11:51 AM
merc225hp's Avatar
merc225hp
Plug the EGR line/port in the exhaust this is unsafe!!!!!!
Old Oct 9, 2013 | 12:05 PM
chromed95's Avatar
chromed95
+1. If you want it to sound like a cummins, put a cummins in there.
Old Oct 9, 2013 | 01:10 PM
TheBigRedTruck
I don't want it to sound like a cummins but it does a little bit. and how is it unsafe? I drive with the windows down anyway
Old Oct 9, 2013 | 02:23 PM
All year round? Not to mention venting nice, toasty warm exhaust gases at the body of the truck.....
Need to plug that hole. If the egr valve is still in the manifold, and unplugged, that probably isn't too much of an issue. A block off plate for the valve would be best.
