Removing 2nd Gen Bumper with hand tools
Old Oct 16, 2013 | 09:44 PM
hometheaterman's Avatar
hometheaterman
Default Removing 2nd Gen Bumper with hand tools
Any advice for removing a 2nd gen bumper with hand tools? I removed mine in the driveway with air tools as I couldn't get enough room to turn a ratchet on the nuts from the inside of the bumper. I got the impact wrench in there and got them off, but it was a pain.
I'm going to try to go get another bumper from a pick a part junkyard. I won't have access to my air tools in the middle of the field so will have to do it by hand. Any tips? I'm not sure how I'm going to do this since I couldn't get the ratchet to turn at all on the nuts before since it was soo tight in there.
Old Oct 16, 2013 | 10:03 PM
ryan0714's Avatar
ryan0714
well you might try taking a torch and just heat them up a little and they will come loose easier, or just cut the head off and get different bolts, or use a breaker bar. if u can at least get the socket and ratchet on there use a cheater bar.
i think when i did mine i came at them on the opposite side. put the ratchet on the nut side with a deep socket, and a wrench on the head.
Old Oct 16, 2013 | 10:09 PM
dhvaughan's Avatar
dhvaughan
i removed my front and rear bumper with hand tools. 18mm socket, deep and shallow, ratchet, extension, and a long 1/2 inch drive pull bar. and lots of pb-blaster penetrating oil.
clipper77's Avatar
clipper77
Assorted open ends, ratchets, extensions, sockets, etc.
I cut the bolts on mine when I removed the front bumper.
Have never removed the rear.
Old Oct 17, 2013 | 08:11 AM
AtomicDog's Avatar
AtomicDog
Are you referring to the front or the rear bumper?
I pulled a rear bumper at a salvage yard a while back and used hand tools without an issue. Just took a lot of PB Blaster, patience and internal fortitude to get the job done...
Old Oct 17, 2013 | 11:54 AM
Unbolt it from the frame instead?
Old Oct 17, 2013 | 11:59 AM
Ham Bone's Avatar
Ham Bone
This is what I did. It's really easy that way
Old Oct 18, 2013 | 01:51 PM
hometheaterman
Sorry I should have clarified. I was talking about the front bumper. When I took mine off I removed it from the frame with the brackets still attached to the bumper and then I took them off after the bumper was off. I still couldn't get a ratchet to turn on the bolts holding it to the frame as inside the bumper it just didn't seem to have much room. I somehow wedged the impact wrench in there and got them off with that. I'm thinking maybe I can do it with a ratchet and breaker bar if I have to though which is what I'm hoping.
