pulled 46RH-- cant get TQcon OFF??
Old Oct 19, 2013 | 08:47 PM
turboracer1994's Avatar
turboracer1994
Default pulled 46RH-- cant get TQcon OFF??
we got my sons trans pulled today. and for some stupid reason, we cant get the TQ converter to slide off the input shaft( bellhousing end of the transmission) is there a lock or something on there? I tried turning it just incase the splines are not lined up, wiggled it up down, sideways etc. it just wont come off.... any ideas???
the trans oil was burnt, filter was BAD!! no metal flakes in the filter or oil pan, the magnet had a bout 1/4" of crud on it. looked to be a LOT of clutch material in the oil. so here we are... pulled it.
any ideas on getting the TQ converter off???
thanks for the help/ ideas :O) much appreciated.
BTW 1995 5.9L 2WD auto- 46RH trans 188K miles.
Old Oct 19, 2013 | 10:48 PM
AtomicDog's Avatar
AtomicDog
The torque converter just slides onto the input shaft - there is nothing special that holds it in place. I would put a pry bar in between the back of the converter and the front pump to wedge it loose. Like you mentioned, sounds like the transmission was seriously overheated. Since the transmission is going to be rebuilt, I wouldn't hesitate to use a pry bar on the converter, since that converter will likely need to be replaced or rebuilt.
Old Oct 19, 2013 | 11:08 PM
ryan0714's Avatar
ryan0714
love tap it with a rubber mallet and break it loose?
Old Oct 20, 2013 | 04:29 AM
turboracer1994
ended up dropping the large end of the case about 24" down onto wood blocks to get the converter off- its was basically welded to the oil pump shaft. the oil pump bushing, gears, etc are junk, the center pump gear was broken in 2 pieces. the seal was gone!!! but its out now---
ordered a master rebuild kit, TQ conv, oil pump, and ATSG manul to get it rebuilt. is cheaper and better than dropping in a junkyard trans back in to it...
Old Oct 20, 2013 | 12:09 PM
Keep track of your costs please, and let us know what you do, and how much you spend. I have a 46RE core in my barn just waiting to get rebuild.
Old Oct 20, 2013 | 12:51 PM
AtomicDog's Avatar
AtomicDog
HeyYou, just FYI, he has a 46RH, which should be a bit less expensive than rebuilding a 46RE, which has more electronic controls. I had a core 46RH rebuilt by a local rebuilder here and it cost me about $1600 - this included a full rebuild kit, remanufactured converter, TransGo shift kit and ultra-deep TCI cast aluminum pan, parts and labor. Luckily, all of my transmission hard parts were in good shape and reusable.
Old Oct 21, 2013 | 07:56 AM
turboracer1994
Bought so far- ONLIne-
master rebuild kit- $169
ATSG Manual $23
New oil pump assembly (reman if i remember right) $119
Filter kit $12
Transgo Jr shift kit $35
New coolerline with check ball removed $25 (short part of line only not the entire 80" of it)
ATF +4 trans oil at $5.25 qt x 8 so far-- will probly need more--
still need to find a TQ conveter for decent price----
so far sub total: $423-
Old Oct 21, 2013 | 09:31 AM
Spend at least 200 bucks on a converter. The 80 dollar fellers aren't worth it.
Old Oct 27, 2013 | 11:12 PM
turboracer1994
ordered TQ converter $158 from OPT.
new rear band- $30 Kevlar- ebay
2 rolls of shop towels $3
3 bottles of purple degreaser $3
lots of time with son on his project--priceless =o)
going good so far- waiting on parts to show up- everything almost all ready for assembly....
Old Nov 15, 2013 | 12:07 AM
turboracer1994
1st post in parts $423.
2nd post update- + $194 - $25 returned cooler line
last parts- transmission grade Hose summit racing- $8.95
trans drain plug kit $5.95
8x hose clamps @ .45 each = $3.60
Grand total= $ 610.50-
-KEEP IN MIND-- DID NOT REPLACE (or needed to replace) any hard parts BUT the oil pump assembly-& TQ converter-- all others checked out fine.
Installed the transmission last couple days- drove the truck today- no issues, no fault codes, shifts great. =o)
