Loud grinding noise under load, transfer case maybe?
Old Dec 8, 2017 | 11:48 AM
  #31
Replace the chain. While you are in there, see what else is worn beyond usability. Unfortunately, you won't know, until you have it scattered around the bench, and can see what ya got.
Old Dec 8, 2017 | 02:09 PM
  #32
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by rgviewer
I think I will change the rear diff fluid as DodgeRam23 suggested. I see the rear pumpkin around the fill plug wet. Any idea how to get this to seal up.
Also I am thinking my catalytic converter may be plugged, as It seams to not accelerate very well and feels like there is a loss of power. Maybe one of these are causing the vibrating, rumbling noise that I heard.
I use Lube Locker gaskets. I actually reuse them to (doesn't say you can but 2 vehicles and 8 diff changes it still seals up)
Old Dec 8, 2017 | 03:22 PM
  #33
beau680's Avatar
beau680
Yup. You can find them here. (and various other places.) If your truck is high-mileage, wouldn't hurt to check how much chain slop you have as well. I know in my 96 with 200K miles, 4wd is all but useless, as the chain is stretched so much, it slips on the gears.
yeah it’s got 192xxx I can here the noise when I’m on the gas while coasting a bit I’m sure the noise is there at higher speeds i just can’t hear it as well.
What kind of symptoms does the loose chain give off other than not holding in 4x4
Old Dec 8, 2017 | 03:32 PM
  #34
If it's really bad, it'll slap the inside of the case...... Mine is only noisy in 4wd, perfectly quiet in 2wd. If it is growling all the time, need to see what's going on, before it blows up.
