Timing set
Old Oct 24, 2013 | 10:10 PM
AppelH's Avatar
AppelH
Default Timing set
Gonna replace my timing set while I have the motor pulled, among a few other things. My dad seems to think we need to pull the harmonic balancer to get the timing cover off. Is this true? Just need to know if I need to track down a puller before we start the project.
Old Oct 24, 2013 | 10:14 PM
merc225hp's Avatar
merc225hp
The HB must come off to change the t chain. Depending on the type of HB you have it could be a possibility of two pullers, one that uses three bolts to pull and then just a two jaw puller. I am sure you know this but I will post it anyway don't pull from the outside of the HB you will destroy it.
Old Oct 24, 2013 | 10:19 PM
AppelH's Avatar
AppelH
I didn't know that. I have never actually messed with a Hb before. Pops said he has a kind of "do all" puller that he uses at work. Hopefully we can get that to work, if not might be able to rent one.
AppelH's Avatar
AppelH
So basically don't try and get it off without the right tool
Old Oct 24, 2013 | 10:26 PM
merc225hp's Avatar
merc225hp
You got it. Somewhere here on DF there are pix of the two types of HB's. I know the search function kinda works here you might try a search for HB removal. Then there is the good old FSM it should tell you what you need for a tool.
Old Oct 24, 2013 | 10:30 PM
Ham Bone's Avatar
Ham Bone
if you go to rent one, the parts store generally has a separate, "Chrysler small block" puller.
the three jaw puller hooks on the inside, most hook on the outside
Old Oct 24, 2013 | 10:59 PM
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
AppelH,
Are you doing this here in Ellensburg or somewhere else? I have pullers too if you need something. I still have my new engine on the stand so you could see what it looks like.
Old Oct 24, 2013 | 11:08 PM
dhvaughan's Avatar
dhvaughan
just remove the fan and shroud, belt. ps accessory bracket?
use a 1-1/4 socket on the big crank bolt.
if you have an impact wrench, just zip it off.
if you don't, then you'll need to rig up method to prevent the engine from turning. a flat piece of steel bolted to the harmonic balancer works good.
if the water pump is old, replace it and the front crank seal. it will come in the timing cover gasket kit.
Old Oct 24, 2013 | 11:21 PM
AppelH's Avatar
AppelH
Wildman,
I'm actually in Cle Elum now, but no I don't have anywhere to do it so will be taking it north to my dad's shop. I will see what my dad has, I may hit you up for a puller since you offered.
Old Oct 24, 2013 | 11:22 PM
AppelH's Avatar
AppelH
So if I could get access to air tools I may be able to get away with no puller? Or am I confused about something?
