stoped running
Old Oct 26, 2013 | 05:58 PM
lmshowalter's Avatar
lmshowalter
New Member
Default stoped running
I have a 98 ram 1500 4x4 5 spd. 318 /5.2 engine 240000 miles was running great went to work shut it off then restarted , then just died tried to re- start now just turns over and sorta trys to start,has spark to plugs(new) cap and rotor(new)can smell raw gas thinking timeing chain but no backfire thru manifold. any ideas please.Thanks Lee
Old Oct 26, 2013 | 06:27 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Check fuel pressure with a gauge .
Old Oct 26, 2013 | 07:43 PM
lmshowalter
New Member
Ok Good thought all my other trucks are 1st gen diesels would not have thought of that thanks Lee
Old Oct 27, 2013 | 03:24 PM
lmshowalter
New Member
Ok I have 45psi for fuel pressure any other thoughts or am I still going to the timing chain?
Old Oct 27, 2013 | 03:32 PM
zman17's Avatar
zman17
Got spark and fuel, next, I would unscrew the precat o2 sensor from the pipe and see if it starts.
Old Oct 27, 2013 | 05:30 PM
lmshowalter
New Member
thanks will do Zman17
Old Oct 27, 2013 | 06:25 PM
lmshowalter
New Member
no go with o-2 removed
Old Oct 27, 2013 | 07:38 PM
Are you getting injector pulse? Should be able to pick up a noid light at your local parts store.
Old Oct 28, 2013 | 01:12 PM
zman17's Avatar
zman17
Also, do you have a nice strong blue spark?
Old Oct 28, 2013 | 02:49 PM
lmshowalter
New Member
Getting injector pulse.It backfired once then never again,got spark thru plugs im workin outside by my self can see spark but can't tell if it is blue also have new coil on it but did not change wires.going nuts with this (some times I really love my diesel)
