Please help. very bad leak on 98 Durango
Old Oct 28, 2013 | 11:12 PM
WolfSlinkard's Avatar
WolfSlinkard
Default Please help. very bad leak on 98 Durango
I have 98 Durango, me and my dad changed the water pump on it hoping it would fix it and now when it runs it seems fine but once we shut it off it sprays a huge amount of coolant out of the front of the motor. it seems like it maybe a intake gasket but I have no idea. any help would be very appreciated.
Old Oct 28, 2013 | 11:16 PM
SilverSS's Avatar
SilverSS
Can you take a pic of where exactly it is coming out?
Old Oct 28, 2013 | 11:17 PM
WolfSlinkard
ill see if i can tomorrow. i tried to today and it was so bad it was splashing onto my camrea
Old Oct 29, 2013 | 12:11 AM
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
Maybe the bypass house going from the front of the intake to the top of the water pump?
Old Oct 29, 2013 | 12:16 AM
WolfSlinkard
that was my first though but oddly it was one of the only dry spots
Old Oct 29, 2013 | 12:46 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Stupid question, but have you tried cleaning it off best you can, then firing it up?
Old Oct 29, 2013 | 01:09 AM
WolfSlinkard
ya we tried a few times and the same thing. runs fine drips a little then we shut it off and it spews coolant every where
Old Oct 29, 2013 | 01:12 AM
WolfSlinkard
it seems like it comes out closer to the passenger side and above and behind the water pump
Old Oct 29, 2013 | 01:13 AM
AtomicDog's Avatar
AtomicDog
You can also use a cooling system pressure tester to pressurize the cooling system at the radiator inlet without running the motor. This should easily show you where its leaking. You can typically rent the tester for free (once you return it, they refund your deposit) at a local parts store, such as Advance Auto and AutoZone. Here is what one looks like:
http://www.stant.com/consumer-products/cooling-system
Some suspect areas are the timing cover or water pump gasket(s), the water pump bypass hose, loose radiator or heater hoses (forgot a clamp or its loose), etc.
Old Oct 29, 2013 | 01:40 AM
WolfSlinkard
pressure tester sounds like a good idea. my dad was guessing it was the time cover gasket or something with the intake manifold
