4 x 4 Clunking Noise
Old Nov 17, 2013 | 03:36 PM
bmickman's Avatar
bmickman
Default 4 x 4 Clunking Noise
Driving down the road there is no noises from the truck, I then engage in to 4 wheel drive, ONLY when taking out of 4 wheel drive there is a clunk/jerk noise.
It is a 1999 Dodge Ram 1500.
Any suggestions what this could be would be appreciated.
Thanks.
Old Nov 17, 2013 | 04:45 PM
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
Well we could use a little more info. What transmission? What engine? You say it clunks & jerks when taking it out of 4WD? Or are you saying that when you're in 4WD and taking off from a stop it jerks & clunks? What size tires? Any lift? Other mods to the truck?
Old Nov 17, 2013 | 06:20 PM
bmickman's Avatar
bmickman
there are no noises at all driving down the road. It engages into 4wd fine, again there are no noised. But once I disengage, it jerks and clunks for a split second and then is fine once in 2wd.
Old Nov 17, 2013 | 06:31 PM
You on dry pavement while doing that? If you are, then, DON'T do that. Tires need to be able to slip a bit, on pavement they can't, so things break instead.
Old Nov 17, 2013 | 07:47 PM
Wildman4x4nut
Veteran: Army
Can you answer these questions plz to help us help you?
It sounds like it staying in 4WD for a second longer and then pops out and back into 2WD. But without a little more info it's hard to say.
As HeyYou said if you're doing this on a hard surface then that is a big part of the problem. So AGAIN shed some more light on the issue and maybe we'll be able to help.
Old Nov 18, 2013 | 12:17 AM
master tech's Avatar
master tech
Site Moderator & Tech
You may have a broken snap ring on the output shaft that comes out of the transfer case. Its a was a common problem back in the day.
